Spektrum
#841
Originally posted by S-T-R-l-K-E-R
would the spektrum work with the new M11?
Hey S-T-R-I-K-E-R!
No it won't. Currently the M8 is the only Sanwa/Airtonics Transmitter the Spektrum module would fit into. I believe the M11 has a few more extra pins in the back as compared to the M8. I guess only time will tell though. If they eventually sell as many M11 Transmitters as M8s.... you can bet Spektrum would make one for it!
Take it easy and see ya at one of the tracks sooner or later!
#842
Recent Spektrum Successes
I just got my Spektrum receivers back from horizon... they got them reprogrammed and sent out within 3 days. Not amazing, but not bad either
I drove this weekend with the spektrum used in conjunction with my Helios, Quantum Comp 2, and Futaba S9451 servo... no problems, and no need for the external capacitor.
I also drove my sedan with a QC2 and KO 2343 servo, and that seemed to work just fine once I started using a 6.3v 4700 uf capacitor.
Yay!
Yay!
#843
Equipment
3PK, LRP Q2, KO-2143 servo
Problem reciever power goes off and on, turn the wheel full throw on the 3PK and the steering jerks in the direction that I turned, tested other servos steering problem went away
Equipment
3PK, LRP Q2, Airtronics 94758 servo "Brand new 139 bucks"
steering problem went away but the power goes off and on still
My radio was the last one to come out, so the programming should have not been a issue. Who the compay rep. in this forum?
Equipment
#844
Originally posted by dawgmeat
Equipment
Equipment
Equipment
Equipment
is this the one that come with the LRP worlds upgrade kit or can I can I hit up radio shack?
#845
I used my spektrum for 3 weeks with a brand new ko helios on a on road nitro 1/10 car. it worked great until the first real race of the season when the failsafe would kick on when the car was 100 yards or so away. i originally thought it was the personal transponder but it is ok. i just found out my jr 8450 servo(i am using it for throttle/ brake) is going bad and it heats up considerably and causes the steering servo to wobble back and forth constantly. would a bad servo cause the failsafe to kick in and is there a way to tell other than putting the dsm back in the car if it has been damaged by the defective servo?
thanks for any help.
mike l.
mike l.
#846
From: Castle Mamba Max Pro. Feel its power!!!!!!!!!!
Yes a damaged servo could make the fail safe go off if it causes interferance. I would start with trying another servo and then run the car and see what happens.
#847
mike l.
mike l.
#848
Rocketron,
that is exactly what i was thinking because the servo was very hot after being on for just a few minutes. i bet it drained the battery too fast and kicked it on. that would be great if that is all that it is, although an 8450 or that new 8008 ain't cheap to replace it.
cheaper than a spektrum but not by a lot,
#849
But if your servo is going bad, you're going to have to replace it sometime. . .better sooner than after it fails during a race going down the straight at full throttle - and into the wall. . .
Generally, as motors and electronics get hot, they do draw more power and the Spektrum is more sensitive to low power conditions than are the "passive" receivers we've been using forever.
Which makes sense - we've got a small processor in there which is why we can all turn on our Spek's without killing each other!
#850
Equipment
Equipment
Equipment
Equipment
#854
Originally posted by JRX-S Bill
Anyone know if I should have my KO Helios set to High Response on the radio's switch hidden under the plug-in Spektrum transmitter module?
Thanks.
Thanks.
