Spektrum
Old 12-16-2006 | 09:49 AM
  #1966
Originally Posted by Mr. Shookie
Use Normal mode.
-Shookie <><
thanks a lot
harris is offline
Old 12-18-2006 | 11:14 AM
  #1967
TFR's Avatar
TFR
Anybody able to fit the module top cover on their 3PK with the Spektrum module? This Spektrum PRO module sits higher than my Futaba 2.4Ghz. If it wasn't for the small size receiver I would not buy this product. The module was a tight fit in the 3PK as well...
TFR is offline
Old 12-18-2006 | 11:55 AM
  #1968
ngo8's Avatar
its normal but it fits a little tight
ngo8 is offline
Old 12-24-2006 | 12:44 AM
  #1969
bmmer701's Avatar
Default re
hi i was just wondering if someone can teach me how to bind the micro rx? thank you so much. i don't have any manual
bmmer701 is offline
Old 12-24-2006 | 12:58 AM
  #1970
nnick's Avatar
Shop Owner
When you receive the receiver you should also have a connector.
It is used for shorting but I can;t remember by heart in which slot you should put it, and that's it
Nick
nnick is offline
Old 12-24-2006 | 06:22 AM
  #1971
bmmer701's Avatar
Default re
hi nnick it doesnt have any connector... is there a specific connector for that? thank you so mcuh
bmmer701 is offline
Old 12-24-2006 | 06:50 AM
  #1972
together with the micro, comes a connector that you need for the binding... normally it is on the receive on the battery...
See the attached file...
it close the circuit in order to bind the receive.... if you dont have it... you can make it.. just close the left and right hole with a cable...the middle hole is empty
harris is offline
Old 12-24-2006 | 06:53 AM
  #1973
bmmer701's Avatar
Default re
ok i've tried it with one wire and i noticed that the light started to blink but it won't bind on my module. trial and error maybe? what i did is when i turned on my rx then the light started to blink then i turned on my tx at same time pressing the button of the module then it started blinking also but after some time the light of the module stays lit while the rx was still blinking
bmmer701 is offline
Old 12-24-2006 | 07:13 AM
  #1974
nnick's Avatar
Shop Owner
Yeap, what Harris wrote
Here are the instructions!!
Nick
nnick is offline
Old 12-24-2006 | 07:32 AM
  #1975
bmmer701's Avatar
Default re
ok will try it thanks
bmmer701 is offline
Old 12-24-2006 | 07:33 AM
  #1976
TFR's Avatar
TFR
Nick
One question, after we bind the first time and hit the track. Do I have to repeat the process again on my next run?
TFR is offline
Old 12-24-2006 | 08:02 AM
  #1977
bmmer701's Avatar
Default re
geesh... it doesn't bind hehe.. i noticed that if i turned on the rx with the servo installed the led doesn't light that bright but if i will remove the servo plug the led will be bright. hehe...
bmmer701 is offline
Old 12-24-2006 | 10:56 AM
  #1978
firs you push the button and then open the transmitter... be carefull
harris is offline
Old 12-24-2006 | 10:57 AM
  #1979
no only one time you have to do it...
harris is offline
Old 12-24-2006 | 08:02 PM
  #1980
bmmer701's Avatar
hehe it won't bind the led on the rx still flashing even if the led on the module stop flashing already...
bmmer701 is offline
