HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
Got a 8.5 V10 G2 motor that need a new hall sensor module. Bought one for the V10 from amain and it has 2 screws that hold it on like on my older V10. The motors I have have 1 screw in the middle. where do I find these sensor modules? I can't find it anywhere.
Leaky capacitor
Can the capacitors be replaced in the xr8 ,i got a leaky cap .
Hello all. I have HW esc's and motors in all my vehicles and I love them. I currently run a17.5t & 10.5t motors in my 2w buggy and 2w sc respectively. Both are Bandits and impressive. My problem is that I'm going to be entering in a ROAR sanctioned event in the next two months and last I checked these motors weren't sanctioned for legal stock or sportsman classes. My question is how do the legal HW motors stack up against the Schuur Speed Selects and Fantom Specials? Thanks for any help or suggestions.
If you are willing spend the money, pick up the select/team rotor versions of either the Schurr speed or Fantom and you will get as close as possible.
Thanks! Just what I wanted to know.
Anyone ????
I believe the new G2 version sensor boards are the one screw variety. This is how my latest edition 7.5 G2 is setup. My older versions have the dual screw setup for the sensor board. I would suggest contacting HobbyWing directly.
Hobbywing help no good
Does hobywing ever reply to these posts ? I cant get a rise out of them anywhere ? All i want to know is where to get replacement capacitors for the xr8 plus esc !or what is the usual way to fix this simple problem we ae having here in australia ! I CANT GET THROUGH ON THERE SITE AS IT WONT EXEPT MY EMAIL ADRESS ,!
Can't change network name or password on wifi express
Got the wifi express this week and it works great EXCEPT when I change the network name it won't connect with the esc anymore. The phone will connect with the wifi express but then the wifi express won't connect with the esc. The esc is an sctpro, which works fine with the card, box, and hooking it up to my tablet. Anybody have any ideas? Tks
Cheers Mate !
Lost the little rubber button on the on off switch... completely my fault(servo tape let go in the middle of a run) I was wondering if I can buy just that part?
For those looking for support your best to email direct.
Angelo is located in Australia and can be reached at [email protected]
Charlie is located in California (HWNA) and can be reached at [email protected]
These are your BEST places to get support.
Hope this helps some
BRAKES!
Any reason to not update firmware for SCT Pro?
I have qty2 that have been sitting for 1-2 years, and are finally getting used.
I see HW has quite a few firmware updates since I purchased these (both for the esc and the LCD programming box). They will be running Tekin motors.
Sooo, update the firmware?
