Speed Passion Thread >
Like Tree4Likes
Old 07-25-2012 | 10:58 AM
  #1486
midwestcajun's Avatar
Originally Posted by Solara
Not enough lipo to power that thing...beside, who would like to play 5 minutes with 2 hours of charging..?
Noticed the price on the Silver Arrow 2 is a super low $63. Is this because a newer version is coming available and if so what were the issues with the old one. That's too good of a price to pass up. Also I have the programming box for the HobbyWing system....will that work on this ESC as well? Thanks.
midwestcajun is offline
Old 07-25-2012 | 11:03 AM
  #1487
Cain's Avatar
Tech Legend
in general from those I have talked with before purchasing the SAV2 it appears main complaint was overall size of the ESC. Failures were in line with whatever everyone else is seeing in general in 1/8 electric, maybe a bit less. Main plus I heard about personally was how smooth it is as well as the fact it stays cool.
Its also wired out of the box for dual lipo usage so for those who need that, you are all set basically out of the box.
If you have the LCD Programmer box, the one that will work with the GT2.0 speed controls, my personal experience is that it works using Speed passion only firmware, etc. Pretty nice not having to lug around a pc.
Cain is offline
Old 07-25-2012 | 12:26 PM
  #1488
Cain's Avatar
Tech Legend
what software is recommended when using the SP GT2.0 Pro in 4x4 SCT with a 4 Pole 540 motor? I have read that 205MOD works but there is another MOD profile that is even better (runs cooler), just can remember which.
Cain is offline
Old 07-25-2012 | 01:05 PM
  #1489
See you can find out from someone that successfully unload the HW firmware and load the SP firmware on the HW box...I know it can be done.
Don't expect the new one coming out anytime soon....we are just blowing those price out simply because.........we have nothing to do. Really.
Solara is offline
Old 07-25-2012 | 01:08 PM
  #1490
From what my drivers told me, they were never use 205g anymore because it is slow.....they are all running 428STOCK with boost and supercharger along with the 4x4 used motor. I have seen some using it on NOVAK and some on TEKIN (but I have not seen that in person)....some of the drivers are running the prototype Speed Passion BLAZE 4x4 SCT motor and actually they are using it at the up coming Futaba Race that host at Leisure Hour Raceway this weekend.
The BLAZE should be release around end of August.....as well as the 1/8th version of the BLAZE motor.
Solara is offline
Old 07-25-2012 | 01:25 PM
  #1491
Cain's Avatar
Tech Legend
Originally Posted by Raul Garcia
I also had a chance to run the new 4400kv 540 4 pole motor this weekend, and all I can say is wow, its a rocket. I am using it with my SP 2.0 Pro, profiles in 119mod, 528mod, 205mod. It runs like a top.
Of the three profiles Raul mentions, which is the one with better temps in 4x4 SCT on 2S? I thought it was 119Mod, can't remember.
For 428STOCK, what do you need to set the various options to to turn off a certain feature like boost and super charger?
Cain is offline
Old 07-25-2012 | 03:39 PM
  #1492
Mark Erce's Avatar
I use the hobbywing on mine with no issues, but im going to get the SP box just so I can easily download the lastest software. plus Im running the Sp stuff in my 10th scales this year!
Mark Erce is offline
Old 07-25-2012 | 11:33 PM
  #1493
onekiwi's Avatar
Hi all
Got a Q I have an older motor SP competition series 2.5R what is that compared to today?
Is it still a 2.5 or as escs have gotten better since this release maybe its more like a 3.5/4.5 maybe?
thanks
onekiwi is offline
Old 07-26-2012 | 08:20 AM
  #1494
Originally Posted by onekiwi
Hi all
thanks
2.5 is always 2.5 but it is just too high of a rpm motor that I don't see it has any use for real racing unless you want to do DRAG racing. Also, now a day ESC has BOOST and TURBO feature...running that will the 2.5 motor, if not setting it correctly you will smoke that motor in no time.
Overall, you can still use that motor....
Solara is offline
  #1495
SOLD! Did you have to do anything different with the HW box or was it a plug and play situation?
Old 07-26-2012 | 09:33 AM
  #1496
1mrdad's Avatar
Default Quick Basic Set-up Question
I have always run 17.5 blinky, and I am now going to try running mod 2wd buggy by boosting my Revtech 17.5 (12.5mm HT rotor) motor. I am planning on initially testing with the motor timing turned all the way down and using the boost adjustments on my GT2.0. I am using V3.0_120428Stock software. I see the boost timing maxes at 64 and the turbo timing maxes at 40. Do the numbers reflect actual timing in degrees, or are they just a linear scale? Also, how do the 2 different timings interact?
1mrdad is offline
Old 07-26-2012 | 10:06 AM
  #1497
Mark Erce's Avatar
it was plug and play. but i would just get the SP box so theres no issues with downloading the latest software.
Old 07-28-2012 | 09:38 PM
  #1498
Default GT 2.0 Black Edition
Hey Guys,
I just received the above mentioned ESC by fed ex today and it comes with a programming box. Do I need anything else to get me going? I am going to give this esc a try with a Thunder Power 5.0 550 motor in my Durango DESC 410. I'm currently using a Tekin RX 8 with a 4000 4 pole motor and appreciate any feedback you can give me.
Thanks,
knowitall156 is offline
Old 07-28-2012 | 09:54 PM
  #1499
I just got a 10.5 Ultra Sportsman V3 motor and looking for some confirmation on my initial gearing. It is being used in a 2wd off-road buggy. The transmission ratio is 2.6, and i am starting with a 72/30 combo, which gives a 6.24 fdr. Is this too much? should it be around 5.6 to 5.8? It seemed from my first run that the motor temp wasn't too bad, but the ESC seemed a bit on the hot side. I'd appreciate any help, as i am still learning when it comes to running brushless.
AntiGooch is offline
Old 07-29-2012 | 11:35 AM
  #1500
Cain's Avatar
Tech Legend
Silver Arrow V2 maiden voyage as excellent. better than how my silver Arrow V1 went.
May move it to the other side of my car since its so big to get better room for pinion mesh.
Cain is offline
