LRP SXX StockSpec V2 ESC >
Old 04-16-2012, 05:46 PM
  #886
bhambrent's Avatar
Originally Posted by Dane
Anyone know what the part# is or When it will be available to buy ?
Thxs
bhambrent is offline
Old 04-16-2012, 06:48 PM
  #887
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Default reading the lights
can some one give me a simple color explanation behind the programming of this esc?
start with mode 1 all the way thru?
Thank you
BlackStarRacing is offline
Old 04-16-2012, 07:35 PM
  #888
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Thank you
Crash course:
Option 1- voltage cutoff. Pretty self explanatory. off, 1s, or 2s.
Option 2 - Throttle profile. profile 0 for blinky mode. profiles 1-4 for lrp motors, 5-10 for non lrp. higher # more aggresive profile
Option 3 - boost. odd #'s are slow ramping, even #s fast ramping. most of the time you use fast ramps. higher # more boost
Option 4 - drag brake - higher # = more.
geeunit1014 is offline
Old 04-16-2012, 07:37 PM
  #889
KHoff7's Avatar
Originally Posted by geeunit1014
Crash course:
This is why Mike Gee is my favorite team associated driver.
KHoff7 is offline
Old 04-16-2012, 08:21 PM
  #890
Crash course:
ok thats what i need can you break down the color scheme?
Boston
Old 04-17-2012, 03:59 AM
  #891
Buckaroo's Avatar
Click here to download the manual
It always amazes me how much stuff in today's society that people operate from web advice, when with so many fewer keystrokes and no risk of misinterpertation, they could simply download the manual.
Buckaroo is offline
Old 04-17-2012, 05:30 AM
  #892
well i have the menu but its not to clear on the color codes that match each setting.... so i figured i would waste a couple of keystrokes and ask for the color codes for each mode:
Old 04-17-2012, 09:32 AM
  #893
zafira2310's Avatar
Default X20 - 10.5T
did anyone know the mode 2 and 3 setting for new LRP X20? i use 10.5T. any idean if i still limit the mode 2 1-4? please help
thx
zafira2310 is offline
Old 04-17-2012, 10:49 AM
  #894
I'm honestly not sure. I find it easier just to keep track of how many times I've presses the mode button to know which option im on. 1(initial) is cutoff, 2 (1 press) is profile, 3 (2 presses) is boost, and 4(3 presses) is drag brake
Old 04-17-2012, 10:56 AM
  #895
briankstan's Avatar
Mode 1. Yellow Led
Mode 2. Red Led
Mode 3. Yellow/Red (alternating flash)
Mode 4. Yellow/Red (same time flash)
here is a link to the manual. SSX Stock Spec V2 Manual
Hope that helps.
briankstan is offline
Old 04-17-2012, 11:47 AM
  #896
Buckaroo's Avatar
It's indicated in the section labeled "Mode Programming" in the instructions. The chart indicates which LED should be showing. Example: Mode 1, LED Flashes: Yellow.
The directions above that specify that the blue LED will flash indicating the setting selection.
Buckaroo is offline
Old 04-17-2012, 01:07 PM
  #897
Got it used this along with below
Originally Posted by briankstan
Mode 1. Yellow Led
Mode 2. Red Led
Hope that helps.
Yeah that helps greatly, exactly what i needed!!! this with the info above i got it now!!!
Thanks to both of you
Old 04-18-2012, 06:12 AM
  #898
Just wanted to thank you guys I figured it out.....the issue was mode 3&4 were on zero so when I was on those modes I got no blue led..... But it's working as it should now.....thanks again
Old 04-22-2012, 11:09 AM
  #899
Default returns?
i sent my esc back and delivery conf. showed they received it... Now do they call you at all or send an email? i haven't received nothing from lrp just wondering
thanks
Old 04-23-2012, 09:18 AM
  #900
RussF's Avatar
Trader Rating: 22 (100%+)
thanks
I had to contact them. They usually answered within a day. I checked back once a week until they finally said my ESC shipped. Its a good idea to keep in touch with them.
RussF is offline
