LRP SXX StockSpec V2 ESC
#901
SXX Upgrade Kit
With regards to the upgrade kit? What was wrong with the old circuit board?
#904
i have ver2 sxx speedy if smooth excelerate from standing start ok, punch it speedy shuts off everything, no lights indercating anything?no steering. turn off switch, turn on switch, everythings on agian. chaged motors, hal senser wire, and speedy setings//???
#906
If you want to check and see if that is the problem, just plug in a 6volt battery pack to the battery port on your receiver and if it works fine like that then its the BEC in the ESC. From what I have found it is a common problem with the SXX speed controls.
#907
cheers russf
#908
Crash course:
Option 1- voltage cutoff. Pretty self explanatory. off, 1s, or 2s.
Option 2 - Throttle profile. profile 0 for blinky mode. profiles 1-4 for lrp motors, 5-10 for non lrp. higher # more aggresive profile
Option 3 - boost. odd #'s are slow ramping, even #s fast ramping. most of the time you use fast ramps. higher # more boost
Option 4 - drag brake - higher # = more.
#909
They can, but relative to the fast ramps, the slow ramps dont feel like they add much power. As long as you have the right combination of motor timing and gear, you wont overheat the motor, and you will be much faster on a fast ramp.
#910
Do u need to upgrade the sxx tc ver 2?
Also what is the highest that u can set your boost with this speed controller
#911
I have a brand new one and am wondering why I should have to buy the upgrade, when it is actually a fix to a defective unit. What ever happened to qualty control? This should be a direct replacement at no cost as they are admitting to their products inability to do what it is itended to do. An upgrade is an optional part not a required part. I think they should issue it as a direct replacement at no cost. I'm leary of even installing mine. I guess I'll keep running my Tekins.
#912
ttyl
#913
gonzo i have been running the stock spec ver 2 since it came out with no issues i had 2 of them both work with no issues i know they were having some issues in mod 12th with the booster cutting out but thats it,i even ran boosted with no problem i would put it in and run it.
ttyl
ttyl
#914
Is the top setting for boost 6 blinks for sxx tc ver 2?
#915
They did replace my unit with a "new" one. However it did take a long time to get it back and I missed a couple months of racing. I asked if it included the new board and the AE guy said he didnt think so since the board wasnt out yet at the time. It doesnt really matter to me as long as the thing keeps working. I ended up buying a spare and installed it before mine came back, so I now have a NIB one just in case it craps out again.
