LRP SXX StockSpec V2 ESC
#1051
Has anyone had a case crumble ? It was bran new mounted it in my tc then within 5min decided to move it used a exacto to cut 1/2way thru the parma foam tape. Then used a automotive flat pry tool to ease it up the rest of the way . I then used reedy contact cleaner to remove the resido from the bottom and it started to crumble . I have always used this to clean my cars/tyers/electronics in the past ...
#1052
ok, iīve got a problem, My esc doesnīt turn on! itīs death, and i donīt know why, i already check if the switch was making contact inside, and the wires but at the end i couldnīt find the problem, can anyone help me finding whatīs going on?.
Thanks!.
Thanks!.
#1054
Anyone with the new board, how are the brakes?
I notice when I run lower FDR's the brakes get very light and soft in blinky 17.5 TC.
I can't run a smaller spur than 64p 93 so once into 45+ pinions the brakes get less and less.
I've swapped out everything to see if it's electronic, but it seems to be a low FDR issue in my old TC5R.
And running TC 17.5 with it............
I called AE and seems they're out of boards again!
Mine are next in line for the update.
Must have been a lot of boards blown up in off-road as they told me they were working on July & Aug returns with the last batch........
Next set of boards should be for the advertised upgrade.......
2 months and counting.
#1057
all running fine
I have 3 which have been uprated with the new board, all going strong but Settings have all changed took a little while to tune in blinky. .
Factory done 2 took 2/3 weeks and 1 took 2 months.
ps In the Uk.
ps In the Uk.
#1058
I bought an updated SXX off rctech and the 1st owner did the install himself.
My question is why is the installed board different than the one pictured on AE & Lrp's website?
See pics below
Installed Board added sticker on the box says lrp #80999
AE & Lrp updated Board from website
http://www.lrp.cc/en/products/new-pr...egler/details/
http://www.teamassociated.com/news/a..._Stock_Upgrade!
See pics below
#1059
See pics below
See pics below
#1061
It was installed by AE.
Much time has passed since that original photo of the upgrade board was published. It is probably a very low priority for LRP to make sure the various pictures match the various running changes.
#1065
I called AE a week ago and they were just doing early Oct ESC's 1/person.
Seems lrp Germany is sending 100-200 boards over every 2 weeks.
My guess is it could be 5+ months to get 2 esc's done.
I'm at 10 weeks waiting for 1 of the 2 I sent in.
I bought an updated esc and run stock 17.5 blinky with no issues yet. If running mod, pray!
