Viper RC -
Trader Rating: 53 (100%+)
check it out--- http://www.shopviperrc.com/SearchResults.asp?Cat=1945
Use the full site.
I have one esc that is nothing working right.. But my question is I have other esc that I would like to send it to get a check up on.. for next year season..
Do I fill out the Return Info. for the esc that just need a yearly check up.
Thanx m
Thanx m
What area are you from? Do you know any of the Viper team guys? Instead of sending it in to get a check up, a team guy could check it out and make sure it is working correctly. What is the ESC that is not working right doing?
If the unit just suddenly starting acting strange - might want to do some basics:
- check all solder joints (re-flow solder)
- re-calibrate speedo
- reset all the settings to default
I know it will cost to get a good bill of health that is cool.
I think I may need a other on/off case.
Does anyone know on a scale of one to fireball, how happy the VF8 motors are running sensorless?
How will the VF8 run sensorless -- just find - if you have a sensorless speed control it simply will pass the power to the motor.
"need another on/off case" what happen to the case??
You can PM me if you have any other questions.
