Like Tree4Likes
Viper RC -
Old 02-27-2014 | 07:34 PM
  #10006
No I mean when you run that 800mhz pwm for brakes, you get that 8th scale whirr LOL
Bob Barry is offline
  #10007
Wildcat1971's Avatar
hmm, interesting
Wildcat1971 is offline
Old 02-28-2014 | 01:07 AM
  #10008
r888ghost's Avatar
Have a question regarding soldering the viper motors. Are you guys tinning both sides? Another thing that I've been having trouble with is getting the excess solder out those grooves in between the a to b tab and the b to c tab? Some people have told me tonight to get a soldering pump. I tried heating up the solder, but it just won't come off the middle completely and I don't want to short out the motor or esc. That's been really frustrating for some reason. On the tekin and and other motors with the flat tabs, I never had a problem getting those hooked on.
r888ghost is offline
Old 02-28-2014 | 09:11 AM
  #10009
Cain's Avatar
Tech Legend
pics of soldering issue?
Cain is offline
Old 02-28-2014 | 09:31 AM
  #10010
rider313's Avatar
get the solder nice and hot on the tabs so its liquid form. then quickly pull off the iron and tap the ESC on a solid surface tabs facing down. then the solder will fall out and you can restart the soldering process this time using less solder on the tabs.
rider313 is offline
Old 02-28-2014 | 09:33 AM
  #10011
bds81175's Avatar
Moderator
You could hit it with a blast of compressed air aimed in the right direction too.
bds81175 is offline
Old 02-28-2014 | 09:34 AM
  #10012
bds81175's Avatar
Moderator
Dang these Minnesota people are smart.....
bds81175 is offline
Old 02-28-2014 | 09:57 AM
  #10013
nikos2002's Avatar
You can also turn the motor upside down, get the solder melted and when you pull the iron away, the excess will stay on the iron. Do that quite often with the warranty motors - its amazing how much solder some people use on stuff. And yes, you can short it across poles if not careful.
Funny you mentioned not having issues with the "bent tab" solder poles. I have seen those touch together and short out, there was a version of Revtech motors that did it quite often.
___________________________________
For the brake conversation on the other page, the higher the brake freq is what makes the car harder to stop at "rolling speed", lower will help that. Also the "squeal" sound you hear, is actually the esc straining at that freq - means its too low or too high - in the example that was given would say too low.
nikos2002 is offline
Old 02-28-2014 | 10:06 AM
  #10014
r888ghost's Avatar
I tried blasting it with compressed air, but no luck. Can that middle piece where the solder is in between the tabs be just fine? Neither the "A", "B", and "C" tabs are touching or solder connected to it. I just didn't want to go any further because I don't want to short either the motor or esc.
Old 02-28-2014 | 11:16 AM
  #10015
rider313's Avatar
To much solder. Like I said. Get it all nice and hot in liquid form and quickly tap it on a solid surface tabs down and it will fall right off.
rider313 is offline
Old 02-28-2014 | 12:18 PM
  #10016
man you can always tell who used to run round cell / brushed motors LOL.
He's right. way too much. Hold it upside down, get it melted, flick it away. Just be mindful of where you are flicking it...LOL
Old 02-28-2014 | 12:38 PM
  #10017
Default i use one of these
i use one of these , I can't imagine not having one …
professorjason is offline
Old 02-28-2014 | 02:17 PM
  #10018
r888ghost's Avatar
Thanks guys! Got it.
Old 02-28-2014 | 03:38 PM
  #10019
DavidAlford's Avatar
I don't have much sensitivity in my finger tips from years of soldering brushes on motors. Those were fun days though. Kids today have it so easy lol
DavidAlford is offline
Old 02-28-2014 | 03:46 PM
  #10020
nikos2002's Avatar
a64 is official posted at viper-rc.com for all 4 models of VTX speed controls!!!
Please take a minute to download and review the release notes there are some important points about which profile to use!!
