Like Tree4Likes
Viper RC -
Old 07-16-2011 | 02:24 AM
  #2251
smokinu's Avatar
Originally Posted by Cult Racing
the night started off good, then went bad during my second qual when i was 2nd and then my caps blew on me. Will it still work without it or do i need to buy the replacement from amain?
you and those caps
what are you doing to those poor caps? im asking for real.
i have not had a single problem in either of my esc's
What servo are you running? do you have your end points set right
and its in an sc10 4x4 right?
smokinu is offline
Old 07-16-2011 | 12:04 PM
  #2252
You are the only one blowing caps cult. I cant understand why. Send it back again. What batteries are you running? and check the spec on the servo see what voltage it is. This is a very isolated issue. post a pic please....
SC_RAGE is offline
Old 07-16-2011 | 03:03 PM
  #2253
HI,
I have a problem, my motor VST 8.5T is really hot. with the ESC VTX10 set at 220* for motor cut-OFF, my car stop on the track.
I have basically the profile 2 (with some modifications on the braking).
I drive a losi22 with pinion 23 on a track in astro. final ratio = 8
What should I do? I'm the only one in France in my club have the Viper
pitipotinou is offline
Old 07-16-2011 | 04:02 PM
  #2254
Cult Racing's Avatar
Originally Posted by smokinu
you and those caps
i run a losi scte, a hitec 7950 servo. This is the first time i blew a cap none of the less both lol and running xcelorin 6000 60c batt. Can the tekin caps work and ya i have my endpoints set right. It worked great in the first qual so i went up on my gearing and turned the throttle punch from 18 to 16 and then in my 2nd qual my car stopped and smelled like rubber and noticed the caps were gone.
Cult Racing is offline
Old 07-16-2011 | 04:31 PM
  #2255
Race Results
Went racing indoor last night, there was a new guy with a e-8th that was fast, he had me worried. Again my 2050kv viper powered Caster Racing buggy ran flawlessly.
bring it on is offline
Old 07-16-2011 | 08:35 PM
  #2256
Anyone happen to have a release date on the 1/8th scale speedo or is the VTX10R it for 4s? ROAR 1/8th e nats are at my home track and a ROAR regional race the following month, I'm getting ready to put a buggy together and want to order electronics soon.
WideOpenThrottle RC is offline
Old 07-17-2011 | 02:45 AM
  #2257
smokinu's Avatar
Vtx10r in my SC ran great tonight. not a hickup!
Raegan settings esc ran SUPER cool
although i was fighting some problems all day with the truck u qualed 2nd and finished 2nd.
smokinu is offline
Old 07-17-2011 | 06:07 AM
  #2258
itsjusme's Avatar
Can anyone recommend gearing. VTX10 with D3 17.5 in a TLR 22.
Will be running profile #4, 17.5 with boost.
itsjusme is offline
Old 07-17-2011 | 06:13 AM
  #2259
The vtx10r is not recommended for 1/8 scale use. As of right now, team drivers are testing the 1/8 esc with great results but is not available yet.
Poptartninja is offline
Old 07-17-2011 | 06:43 AM
  #2260
Maybe they will send me one and I can test it out at the ROAR E Nats in about 8 weeks
Old 07-17-2011 | 10:10 AM
  #2261
Today I received the Viper 8,5T motor. I will use it in my durango 410 4wd on small and mid-sized tracks. Can you recommend a good starting point for the gearing ? (and ESC-setup for the VTX10)
TopAs is offline
Old 07-17-2011 | 10:59 AM
  #2262
Try runnig a 24. It seams high, but viper motors like a little mor gear. Run it for 3 minutes and temp it, that way you know where to go from there.
Old 07-17-2011 | 11:03 AM
  #2263
savageboy69's Avatar
21 or 22 pinion with 87 spur, preset profile 2 on the esc
savageboy69 is offline
Old 07-17-2011 | 11:14 AM
  #2264
This is exactly the pinion I will try ... I use profile 2 but changed to 0 timing. Is it possible to add some timing on a larger track or will the motor get too hot ?
TopAs is offline
Old 07-17-2011 | 01:40 PM
  #2265
I keep hearing that u have to gear up on pinion but I ended up running 2 teeth lower from ny previous esc and motor.to.keep cool, I need to find a new setup to get some.more rip out of it, right now I'm.at 19/78 in my scr, 30 degrees motor timing, 10 top speed, 10 timing advance, top end is ok, wouldnt mind more but I don't have that bottom end punch I'm looking for
