Savox Servos
Old 05-24-2011 | 12:13 PM
  #436
Asharus's Avatar
FYI, 1257/1258TG works fine without a BEC cap on a Novak Havoc Pro SC
Asharus is offline
Old 05-24-2011 | 02:03 PM
  #437
j_blaze14's Avatar
found a savox knock off, pretty good servo for the price. can be used for parts too.
http://www.hobbyking.com/hobbyking/s...dProduct=12450
j_blaze14 is offline
Old 06-20-2011 | 05:25 AM
  #438
adrictan's Avatar
I got a weird issue with my 1258. It's currently used on the throttle side on my nitro buggy.
The servo has on a few occasions, started doing this: It'll start to twitch really badly for a few secs and then totally has no responses for abt 5 secs and then resume back to normal. All of electronics work fine during this problem. I tried changing a receiver and using another receiver battery so it can't be from these.
adrictan is offline
Old 06-20-2011 | 05:23 PM
  #439
td-civ's Avatar
is your rx a spektrum ?
td-civ is offline
Old 06-20-2011 | 06:10 PM
  #440
adrictan's Avatar
Yep. The SR300 receiver. I use Spektrum on 6 cars and this one on a Savox is the only one with a prob.
adrictan is offline
Old 06-20-2011 | 07:15 PM
  #441
ozzy-crawl's Avatar
have not seen it on nitro cars but it is common on the electrics running savox servos with spektrum to have troubles.with electric cars it depends on the bec out put if you experiance brown outs or not. suprised that would be the trouble running a seperate battery pack
add a cap to the rx.spektrum make one for it (glitch buster) or you can make your own
most electronic shops will have a 4700uf 10v cap for less than $2
just solder a old servo/extension plug (pos/neg) on to the pins of the cap and plug in to receiver.
i have had a few savox servos and really liked them,but i have a mid size one in a pan car and it seems to loose its centre,i emailed savox but never got a reply
ozzy-crawl is offline
Old 06-21-2011 | 01:14 PM
  #442
Titian2010's Avatar
I've seen it happen twice. Once because the vibrations from the motor, think I had a loose motor fin and then again because I let my lipo get to low. Are your batteries fully charge and holding power?
I have a question also for people who run electric of short course. I'm new to short course and need help badly lol ok since I will be running lipo to my reciever Spektrum 3300t, will I need a regulator for non HV servos? I bought the cheap savox 025# something but also have a 1256 for back up to my nitros that I'm gonna try in the truck. Not gonna race it. It's mostly just to drive and have fun. But I'm not trying to see or smell that Nasty smoke that comes out when u fry the electronic. Yes I've done it a few times lol yuck! Thanks
Titian2010 is offline
Old 06-23-2011 | 08:35 AM
  #443
eri3f0g's Avatar
I had the exact problem with a different setup. I had the tekin RS, redline 10.5, and a spektrum sr3000 rx. The savox 1258t is my steering servo. I was able to swap the steering left to right very fast about 3-4 times and then it would "act up". My speed control threw and error code and upon looking it up it stated "low rx signal or power". I bought the $6.00 spektrum rx cap and plugged it into a spare slot on the rx.. problem solved never to return. I actually bought cap's for all my rx's at this point just to remove the chance of a power hungry digital servo from overloading my setup.
http://www.amainhobbies.com/product_...tage-Protector
eri3f0g is offline
Old 06-23-2011 | 09:31 AM
  #444
adrictan's Avatar
The guys are gonna laugh at me for installing a cap on a nitro. Well, I'm sending it back for inspection first and see how things go.
adrictan is offline
Old 06-26-2011 | 12:34 PM
  #445
Default curious
i have an issue using the savox in my t4.1 the way i installed it the servo arm rubs against the top of the servo ,wanting to know if any one has had this problem. thanx.
glacius is offline
Old 06-26-2011 | 06:50 PM
  #446
AZBOB's Avatar
can you use this for any TX/RX?
AZBOB is offline
Old 06-26-2011 | 07:42 PM
  #447
etivac13's Avatar
azob...it should work on any tx/rx...
etivac13 is offline
Old 07-03-2011 | 12:22 AM
  #448
Anyone know if the 1268 can handle 2s lipo/8.4v direct?
I did have mine running through a CC BEC powered directly at 7.4v but today I roasted the BEC and thinking about running the servo directly from my 6s lipo (Mugen MBX5T-E).
I have put together a plug and a Y adaptor servo lead that plugs onto the balance plug on the lipo to get the 2s voltage.
I was thinking that the extra drain on 2 cells would be negligible, not 100% sure but I think would be worth checking out and I wouldnt have to worry about burning out another CC BEC (or is there another/better BEC that can handle 6s input and 7.4v output?).
Shimmy is offline
Old 07-03-2011 | 08:54 AM
  #449
R/C Tech Elite Member
The specs of the 1268SG say "Voltage Range: 4.5v-7.4v"
http://www.myrcbox.com/reiews/review...-1268sg-servo/
Sylvain is offline
Old 07-03-2011 | 09:45 AM
  #450
Yes, I have seen that bit before but it also mentions that no regulator is needed, and also says that its suitable for nitro trucks with 2s receiver packs.
Shimmy is offline
