Savox Servos
Old 04-01-2015 | 11:05 PM
  #586
I have a 2273 hv brushless and 2274 hv brushless in my Nitro buggy. I don't remember which one i'm using for steering, but which ever one it is, the mounting tabs on one side broke clean off from the case. The tab is still screwed to the chassis with the included rubber grommets. Has anyone had this happen? I never had a servo do that before!
My ST-RR EVO is offline
Old 05-31-2015 | 06:11 PM
  #587
BeauFlex's Avatar
Originally Posted by sm_bailey77
Installed sc-0251 yesterday and it fried my mamba max pro. Great servo for the money but was told by a castle tech you need an external bec.
I have that same servo. Ran it with a Sidewinder 3 ESC with no problem. Running it on a Duratrax Onyx ESC right now with no problems. I have read from others that this servo usually doesnt give you the problems that some of the other savox servos do.
Did you end up getting a BEC? If so did it solve your issue? How is it working for you?
BeauFlex is offline
Old 07-16-2015 | 01:48 AM
  #588
dameetz's Avatar
Which Savox Servo model is best to use in a nitro 1/8 buggy? Looking for the best performance and durability (indestructible if can)....
dameetz is offline
Old 07-16-2015 | 07:15 PM
  #589
vandalzzz's Avatar
Maybe 2274? Both st. and thr., no mess with spares
Deal with servosaver and EPA
vandalzzz is offline
Old 07-17-2015 | 04:30 PM
  #590
i have a 1230SG on my 1/8 buggy and it's bullet proof.
voodoo is offline
Old 07-31-2015 | 06:09 PM
  #591
ninzx7's Avatar
Does anybody knows where is the date code in a savox servo?
ninzx7 is offline
Old 08-05-2015 | 06:14 PM
  #592
Its on the side under the mounting tabs.
Sandfreak is offline
Old 08-05-2015 | 06:39 PM
  #593
So found out Savox does not have a repair facility in the states today when I called about a couple servos that need repair that I bought second hand. I should of done more research before buying I guess.
Anyone know of a place that works on off brand servos?
Old 08-08-2015 | 04:40 AM
  #594
ninzx7's Avatar
any other tip? my servos don't have numbers there.
ninzx7 is offline
Old 08-25-2015 | 07:37 AM
  #595
I recently blew some internal on a orion 2067 hv servo and now i am going to replace it with the savox 1270 tg hv servo. Will see the orion lasted about 2 hours in my buggy didnt crash just let go im going to open it up find out
cbrking805 is offline
Old 10-16-2015 | 02:37 AM
  #596
I have a piece of a screw in the spline of servo horn on a 1267. I have also a 1258 with faulty PCB.
Is it able to use the gears of 1258 on the 1267 to fix them ? Or maybe use the PCB of 1267 on the 1256? Can i mix those 2 servos to get 1 working?
Thanks.
djbxp is offline
Old 10-17-2015 | 05:24 PM
  #597
Ive had both Savox and Hitechs.. My Savox have lasted my hitechs even after submitting the hitecs for waranty. I've slowly switched over and happy that I have.
theoutbackdream is offline
Old 10-18-2015 | 10:49 AM
  #598
i really like savox servos and i think that are value for money. Also i have told that are maintenance and recondition capable. That's also good.
i have a 1267 that can't stay still while idle. In general is controllable but sometimes stays locked on a random position for few seconds and then again start moving 10-15 degrees without transmitter input.
What might be the problem? motor or PCB? anyone help please?
djbxp is offline
Old 12-25-2015 | 07:24 PM
  #599
976
Default 1230sg
Can a 1230sg handle a life 6.6 battery
976 is offline
Old 12-26-2015 | 02:39 AM
  #600
In theory yes. Is a common thing that life battery producers claim that life 6.6 batteries are compatible with 6V servos. Actually 6V Nimh would be 7,2-5,5 V when normally working to a 6V servo, life 6,6 Would be 7,4-6,2V when working on a servo.... so it seems that is ok: is like having Nimh battery fully charged all the time. But statistically, life battery can reduce the lifetime expectancy on cheap 6V servos.. i don't think will happen on Savox.
djbxp is offline
