Savox Servos
Old 07-03-2011 | 10:10 AM
  #451
individual1's Avatar
Originally Posted by Shimmy
Anyone know if the 1268 can handle 2s lipo/8.4v direct?
I did have mine running through a CC BEC powered directly at 7.4v but today I roasted the BEC and thinking about running the servo directly from my 6s lipo (Mugen MBX5T-E).
I have put together a plug and a Y adaptor servo lead that plugs onto the balance plug on the lipo to get the 2s voltage.
I was thinking that the extra drain on 2 cells would be negligible, not 100% sure but I think would be worth checking out and I wouldnt have to worry about burning out another CC BEC (or is there another/better BEC that can handle 6s input and 7.4v output?).
There's guys in the Heli world running 8.4 direct to their Align DS610's all day long on 90 sized Heli's. Which are the same as Savox.
individual1 is offline
Old 07-04-2011 | 07:48 AM
  #452
EJF's Avatar
EJF
Will running an unregulated lipo on a 1256 servo cause any issues?
EJF is offline
Old 07-10-2011 | 08:14 PM
  #453
JimmyMac's Avatar
I normally run Sanwa or Futaba servos in my touring cars. I just got a SC10 2wd and I'm looking at trying a Savok servo for this application. Would the SC-1257TG handle this? Or would you guys recommend something different?
JimmyMac is offline
Old 07-10-2011 | 08:16 PM
  #454
Suspended
should work just fine
inferno13 is offline
Old 07-11-2011 | 01:47 PM
  #455
I would suggest the SC-1258TG just to get the slightly slower transit time. The 1257 is wicked fast and could potentially make your truck feel twitchy. I know on buggies it feels dialed, but never tried one in SC.
Banshee8530 is offline
Old 07-11-2011 | 01:52 PM
  #456
td-civ's Avatar
i have the 1257tg in my sc and i had to slow it down i run a 1257mg now and its just right in my losi sc
td-civ is offline
Old 07-11-2011 | 03:45 PM
  #457
JimmyMac's Avatar
Thanks guys. I think the 1257 will suit me just fine. I hate slow servos. If it's too much, I'll just slow it down on my M11x. I just hope it holds up. Thanks again.
JimmyMac is offline
Old 07-11-2011 | 07:28 PM
  #458
the 1258 is still faster than most, but I'm sure you'll be fine either way durability-wise.
Old 07-15-2011 | 01:27 PM
  #459
Maxthepersonz's Avatar
Just wanted to say these guys have the best warranty I have ever dealt with. One of mine went bad and I had a brand new one in under a week. Thanks guys!
Maxthepersonz is offline
Old 07-27-2011 | 10:58 PM
  #460
JimmyMac's Avatar
Just letting you guys know I went with the 1258TG as suggested. Nice servo! Only issue was trying to find a servo horn to fit. I had to press fit a Futaba horn on my SC10 as others have suggested. Is there a "correct" servo horn or true compatible one? Or does the Savox have another unique spline?
JimmyMac is offline
Old 07-27-2011 | 11:01 PM
  #461
JimmyMac's Avatar
..... Or are the SC10 servo horns just that tight? Forgot to add that in because I keep reading Savox are 25 spline like Futaba.
JimmyMac is offline
Old 07-28-2011 | 01:06 AM
  #462
I have read quite a few times that Savox servos are pretty tight fitting, quite often needing to be pressed on.
On my 1268SG, I found my servo horn was also a very tight fit.
Speaking of my 1268SG, it's on it's way back to Savox (I assume they already have it by now), I had a BEC failure (CC 10A) and possibly took the servo with it.
When I initially tested it, it seemed to be working, I got a reply from Savox saying it's fine to run on 8.4v, which I did (to confirm it was working correctly) it stopped after a few seconds.
I was just asked to send it in and if they find a problem with it, they will send me a new one.
Coming from Australia, I thought that was pretty decent, I just hope they do as I've been told.
Shimmy is offline
Old 07-28-2011 | 06:07 AM
  #463
335i's Avatar
I had the same issue with both my b4.1 and sc10. I just end up pressing it on and tightening it down with the servo screw. I have never had a problem with it slipping or anything. I think its just the way they are meant to fit.
335i is offline
Old 07-28-2011 | 06:27 AM
  #464
TAMAK's Avatar
Buy an Aluminum Horn!! These Dynamite horns are only 6 bucks and you wont have to worry about stripping the plastic ones.
Also the Ti geared splines are the only tight fitting ones I have dealt with.
TAMAK is offline
Old 07-28-2011 | 07:10 AM
  #465
335i's Avatar
yea this was both the case for the 1257 and 1258. I was thinking of doing that, but I wasn't sure if any of those horns would work properly in a b4.1 or sc10. Have you had any luck using them on the AE cars?
335i is offline
