NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
#1966
All is good we now have the most reliable and performing products on todays world market and we plan to keep things that way with more improvements and advanced technology .
#1967
#1968
some racers have used it with no fan but to be honest i dont recommend it because with boost settings you will create alot of heat and if you cannot get the airflow to the esc it will cook as some of the motors like the 17.5T,105T,and 13.5T ,11.5T become like mod motors under boost settings .
#1969
cob, we need the rpm firmware, now!
#1971
ddrs <7
Just a quick question on the Speed passion setup sheets it states that when using 528 mod or stock that a DDRS value less then 7 should not be used..
Anyone know why this is and if it relates to the Hobbywing software also? or is it just a Speed passion thing?
cheers
cheers
#1972
level 8 and 9 are very aggressive and could damage your gearing and motor.
Im sure your statement is wrong shouldnt set DDRS to more than level 7 not the way you have written it less than 7 .
#1973
It was some talk about the earlier hobbywing stock softwares that they didn't work correctly is you set the punch to less than 7.
I dont know exactly what the problem was though.
#1974
The problem was solved by the SW 518.
#1975
The new motor comes in blue and gunmetal color. I gues the color is just for show and isn't an indication of a different type of motor? Just like the blue and black esc?
#1976
Its on the speedpassion setup sheets not to use less then 7 DDRS when 422 or 528.. I thought it was weird..
#1977
#1978
#1979
yes the different colours are for looks .nothing different between the black and the blue .the blue represents hobbywings logo colours.
#1980
