NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
#1217
Can I just condirm that the 2 in 1 LCD box will work with the new Xtreme Stock esc. as long as I download the latest firmware for the Program box? (which I presume is available from a PM to Cobraracing)
Specifically regarding item 9, and 12 - 15. Thanks.
#1218
thank you once again for your support of hobbywing.
regards Angelo
#1219
sending email with your software upgrade now .
thank you once again for your support of hobbywing products
regards Angelo
#1220
Yes, it will only work in the XERUN v2.0 series.
As for 8.5R motors, the manufacturer suggests not to use turbo due to excessive heat built-up on the ESC and motor. Although I know some people have tried supercharger with MOD motors. You will just have to use very mild settings and monitor the motor temp.
so its not recommended .Think about it this way you cannot put a big turbo charger on high boost in an actual full size car without decompressing the motor and running massive pipes and intercoolers right ?so the same things goes with brushless heat is a major killer so to run turbo on a mod is the same thing eventually you will kill the esc and the motor.
But you might say ill turn down the settings on the mod with turbo yes you can do that but that will also turn down the performance of the mod motor .
#1221
- brushed 11*2 : speed and acceleration are decent, but a bit soft
- LRP Vector X11 Stock Spec 8.5 (with LRP ESC) (4700 KV, 300W) : better than with my brushed 11*2 but nothing unbelievable
- EZRun with 5.5T (6000 kV, unknown power) : I never managed to get full throttle, even with a 100 meters straight line
So I'm looking for a motor/ESC that could be between my 2 BL combos, around 5500 KV. But with a feature such as this software, I don't really know which motor to use or buy. This car is very strange, with its 2WD, direct drive tranny, FDR is about 3.32 and rollout around 60mm
#1222
I know it's been asked before, but let me remind it once again...
Please Angelo and/or HW revise your instructions so that everything is identical on the LCD and the PDF!
Please!!!
Please!!!
#1223
My biggest gripe, or general future feature request, is I'd still like to see all features called exactly what they are, like static motor timing, full throttle extra motor timing, and rpm timing spread or something like that, all this turbo and boost terminology needs to go, all it does is confuse most people about what the setting actually do.
#1224
Now turbo is known by everyone or boost once you start going to static timing etc not everyone knows those words and will confuse more people ive got guys now from malaysia and other parts of the world that dont understand turbo imagine more difficult words it will be a nightmare .we keep it simple .but if you guys have other ideas please email me and we can vote .
we are a team here and that includes all of us from directors to customers so lets hear what you guys want and lets see what we can come up with .
regards ANgelo
#1228
I know hobbywing check this thread
I working to incrase timing on sensorless mode with atmega8
less noise than sensored method and more safe for all motor not all brand of motor doesnt have same sensor timing
#1229
Hi.
Does anybody know how big the rotor of the XR3650 motor series are?
Thanx
Thanx
