Keyence ESC
Old 09-24-2004 | 06:32 AM
  #196
JDXray's Avatar
thanks nnick, now what websites can i go to get one of these at?
Jon
JDXray is offline
Old 09-24-2004 | 06:37 AM
  #197
nnick's Avatar
Shop Owner
I ordered mine from speedtechrc
Very good price , high shipping charge to Greece though but never mind.......
I found it in other site in US but it was more expensive and also I didn't get any reply on my email!!!
Nick
nnick is offline
Old 09-24-2004 | 07:21 AM
  #198
Pyramid's Avatar
Registered User
Originally posted by asw7576
Keyence ESC...... hhmmmm, something nice for christmas Do you know how much for Rapida Pro ?
Average at USD230 in Asia
Pyramid is offline
Old 09-24-2004 | 07:23 AM
  #199
nnick's Avatar
Shop Owner
Originally posted by nnick
I have Ko Propo's diode (http://www.kopropo.com/super_shotki_diode.gif) what should I put at ENSA?
You missed this question Adrian!
Nick
nnick is offline
Old 09-24-2004 | 07:26 AM
  #200
nnick's Avatar
Shop Owner
Nick
The price $187.99 from speedtechrc
Nick
nnick is offline
Old 09-24-2004 | 07:30 AM
  #201
Pyramid's Avatar
Registered User
Originally posted by JDXray
I wanted to get a Ko Propo Keyence V Extreme for awhile now, but what is the difference between that and the VFS and the other models. Sorry if question has been asked already. I dont want to run my LRP Q2 anymore. I also want to get the KO Propo servos too. But i can wait on that, but i really want to get a KO ESC.
Jon
Decision on LRP.. I totally agreed!
VSF is a very advance Esc, in fact, adjustment range is much more variable/flexible than the V0 Xtreme or Rapida Pro. If you concern about sizes (available space on your car), VSF-1 is the one to go... it is micro in size. Keyence is small.. compared to 90s ESCs.. YES.. but no were near micro.
Last but not least to consider about keyence.. its performance and what it does to your motor will make your life easier and that`s the most important point, at least, to me
Pyramid is offline
Old 09-24-2004 | 07:32 AM
  #202
Pyramid's Avatar
Registered User
Forgot to say that you do need xtra device to do more fexible setting with VFS
Pyramid is offline
Old 09-24-2004 | 07:47 AM
  #203
AdrianM's Avatar
If you are running the KO or Novak diode you need to run the EnSa lower than 100%
AdrianM is offline
Old 09-24-2004 | 08:03 AM
  #204
Lowner_V1S's Avatar
Were can i get a zero v extreme instruction??
Lowner_V1S is offline
Old 09-24-2004 | 11:06 AM
  #205
nnick, in the UK for mod 12 turn racing, we don't tend to change much. We alter the neutral width to either 1 or 2. Most of the guys leave everything else the same, but personally i also up the drive frequency, sometimes as high as 5KHz. This just helps the 12 turn motors, as other wise with the gearing that we usually pull, they are really smoked by the end of the run
Not sure about ENSA value with the diode, as we usually run without
MattW is offline
Old 09-25-2004 | 12:07 PM
  #206
nnick's Avatar
Shop Owner
I'll use the esc without diode after all! I almost fried another esc after diode failure!! (second in one week! )
Here is link for manuals
Nick
nnick is offline
Old 09-25-2004 | 06:48 PM
  #207
S-T-R-l-K-E-R's Avatar
i tried using a rx pack on my keyence rapida pro but i didnt have any throttle. is it impossible to run using a rx pack?
S-T-R-l-K-E-R is offline
Old 09-26-2004 | 11:52 AM
  #208
nnick's Avatar
Shop Owner
What about caps?
Does the esc come with one?
Should I install one? (I own GM's caps, will it be ok to fit them?)
Nick
nnick is offline
Old 09-26-2004 | 03:02 PM
  #209
Striker, i haven't used one personally, but i know someone who has run 4 cell with reciever pack with a zero extreme. You will need to remove the red wire from the reciever plug of the speedo, and then switch both the pack and speedo.
Not sure about caps, don't think you need them but i have never tried one personally, although i have run one with every other speedo. Assuming you are refering to "Power" caps!
MattW is offline
Old 09-26-2004 | 07:14 PM
  #210
Pyramid's Avatar
Registered User
I run 2 diodes with Ensa at 100% all the time
Pyramid is offline
