Keyence ESC
#181
Has anyone run that Novak Schotty motor module thing? If so, where did you attach it. I'm thinking of trying one but there's no way I'm having another set of full size wires coming off my motor. If I can just attach that to the speedo, that would be most convienient.
#182
Suspended
I don't have a Keyence speedo, but I do run the Novak Schottky on my Cyclone. When I bought it the diode (which is on a small 4 layer board) was connected to 14 gauge wires. I don't like smaller wire so I removed the diode (board) and soldered it inline about 1 inch from my motor. Now I can do any motor maintenance without having to do any diode soldering.
#183
Originally posted by AdrianM
I have run my Keyence with 7 and 8 turn mods in a sedan without a heat sink and it doesn't get hot at all compared with the stuff around it. That is not the case will all the micro speedos but you have no worries with a Keyence.
I am a racer and a very direct individual. I want to win when I race. If I thought there were a better speed control on earth it would be in my car and I would not be posting here.
I am a HUGE Tekin fan. I have 2 BC112A's (that I use every weekend) and I used to run G12C3's in all my cars. However, the G10, as far ahead of everyone else it was when it was new, is still 8 year old technology today. Can you win a race with a G10 sure! Just like you can win a race with a Novak Tempest or an LRP V6.
The Keyence is still smaller, lighter, just as tough and has tons more features that racers can actually use and feel on the track.
#184
Originally posted by Pyramid
Let's say we are using the default no5 programming and then run the EnSa. How much more runtime it will generate out of let's say 50% ensa activated? I know it would depend on driving style, but try to give me the figure in percentage..
But the question is..... DOES IT EVEN MATTER?
Before my zero x 2002 I had about 1300-1400mAh left in my packs after a race. After I got the keyence it went up to +1800mAh after each race.
I think this EnSa function should be illegal as all us keyence users already have an unfair advantage!!!
#185
Went up by +300mah, do you meant that the V0 Ex 2002 also has Ensa feature? I used one before but not really pay attention about the Ensa.
#187
Originally posted by tmeeks
The older Tekin and LRP speedos may be "big", but at least they don't burn up like the "latest, greatest" ESCs. We all know that the smaller these things get the more they go up in smoke. When you guys are burning up on the track I'll be screaming past with my "big" G-12cIII (with 12 cells and a 10 turn). Try that with your micro crap!
#188
I heard good thing about this ESC, but lame customer support. The worst customer service probably LRP..... I think I'm done with LRP and move to next level.
Keyence ESC...... hhmmmm, something nice for christmas
Do you know how much for Rapida Pro ?
#190
Unfortunatly I managed to blow mine up!!! running the com too small, won't make that mistake again.
This would have to bee the best speedo I have ever used hands down. The best feature is being able to adjust brake frequency. The higher it is, the sooner the brakes fade as you slow down, making it easier to brake just right everytime.
I have Ko Propo's diode (http://www.kopropo.com/super_shotki_diode.gif) what should I put at ENSA?
I have ordered the Rapida and very anxious to use it!
Any setup for 12T modified will be very appreciated!
I like smooth driving (prefer 12x2 than 12x1)
I totally agree with everyone that said about the new small escs! (I'm fan of GM V12 series)
Nick
#191
just want to give prop to Keyence and adrian. I had a problem with my v extreme and sent it in on monday of this week. Yesterday Adrian emailed me to tell me he got the speedo and will be sending the replacement out today. Can;t ask for better service then that. They follow up with you and let you know the status. I had to do the same with other manufactures and i woudl have to call them weeks later just to find out that they are working on it. Adrian even warned me last month that with the storms, it may take them a little longer to take care of me. So I decided to wait till the storm had passed
I will never change speedo and even thinking about changing to shumacher from xray
#192
You could blow up a speedo if your comm is so small that the copper peels off, shorts out the end bell and you don't get off the throttle until smoke starts pouring out from under your body...lol!
theisgroup - Thanks for the kind words...give me call today when you can (813-889-9691).
nnick - I posted a setup on this thread maybe a page ot two back. Use the Mod setup and change the drive frequency to get the feel you like.
#194
I wanted to get a Ko Propo Keyence V Extreme for awhile now, but what is the difference between that and the VFS and the other models. Sorry if question has been asked already. I dont want to run my LRP Q2 anymore. I also want to get the KO Propo servos too. But i can wait on that, but i really want to get a KO ESC.
Jon
Jon
#195
1. Is the Rapida the Flagship for Keyence?
The Rapida Pro is the top of the line
2. How do the specs compare to LRP Q2 and the ko-propo high-end speedos?
They have half the on resistance of the speedos you mentioned.
Long Answer:
The Rapidas have more individual adjustments. The LRP and KO have diffrent settings for punch and drive frq but you don't have the fine hands on adjustability of the Keyence. You can change drive frq in 100Hz increments from 100-20,000Hz. You can change minimum drive, minimun break, neutral brake and dead band are adjustable in 1% increments. You have 4 memory slots to save setups in. For example this lets you set up 4 diffrent drive frqs which you can switch track side in seconds for back to back lap time testing.
Short Answer:
It does a lot more than the LRP's and KO's.
3. What colors is the Rapida available in?
We can get them in a smoked black case or a blue see through case. However, we only stock the blue ones.
Long Answer:
Short Answer:
