Keyence ESC
Old 08-19-2004 | 11:23 AM
  #151
Sweet, Thanks AdrianM.
NismoSkyline17 is offline
Old 08-19-2004 | 03:03 PM
  #152
etzkev's Avatar
Originally posted by Tim Stamper
Kevin,
Have you checked yours yet. Here's someone else that has the same one as you that checked the menu. The last option in my menu wasn't F_Br, it was listed as E_Br. The same option, but listed differently.
Oh yeah, I won't be able to stay too late Saturday. My sister in law's mom is coming in from Japan on Saturday and we are having a meet and greet. It should be interesting since I know very little japanese and she doesn't speak english.
Tim
Awww man! I will actually be running on saturday too! It's too bad to hear that you won't be there the whole time. Anyways, when I'm at Riders, we can check out the ENSA thing, and I will get the Novak Schottky Diode from riders.
TTYL Man,
Kevin
P.S. That's gonna be damn interesting with your sister in law's mom. I wish I could be there! Haha
etzkev is offline
Old 08-20-2004 | 10:07 PM
  #153
JayBee's Avatar
Smile
the last. They came out a little blurry, and a little small. sorry.
Tim
Hey Tim, you think you can post up a larger picture of you servo mod?
- JayBee
JayBee is offline
Old 08-21-2004 | 03:45 PM
  #154
pumpkinfish's Avatar
I bought my Zero Extreme used and need to put longer wires on it for my Cuda R3. Is it ok to do this or will I risk harming the esc?
pumpkinfish is offline
Old 08-21-2004 | 08:21 PM
  #155
etzkev's Avatar
Yeah, its perfectly fine. I change wires all the time. If you want to keep it pretty though, just dont touch the case...haha. Oh, and try not to heep the hot iron on it for too long. 3 Seconds max probably, or less if possible. Same rule applies when soldering batteries.
-Kevin
etzkev is offline
Old 08-24-2004 | 10:32 AM
  #156
Tim Stamper's Avatar
- JayBee
I'll try. Give me a couple of days to find the disk. There were some other pics on there. I don't have the car anymore. I was the only one running a Yok at my local tracks and I usually didn't have a problem with keeping up with the really fast guys, but I had to work a lot harder. I went out and picked up an X-ray and life never was easier. The car is more stable but more aggressive than the yok could ever be.
Tim
Tim Stamper is offline
Old 08-24-2004 | 10:38 AM
  #157
JayBee's Avatar
Post
That's too bad about the Yoke, but CONGRATS! on the
X-Ray
- jaybee
JayBee is offline
Old 08-31-2004 | 04:35 PM
  #158
Greetings,
I'm in the market for a new Speedo. I have a few questions about the Rapida Pro:
1. Is the Rapida the Flagship for Keyence?
2. How do the specs compare to LRP Q2 and the ko-propo high-end speedos?
3. What colors is the Rapida available in?
Cheerz
Obsidian is offline
Old 09-01-2004 | 09:28 AM
  #159
AdrianM's Avatar
The Rapida Pro is the top of the line
They have half the on resistance of the speedos you mentioned.
Long Answer:
The Rapidas have more individual adjustments. The LRP and KO have diffrent settings for punch and drive frq but you don't have the fine hands on adjustability of the Keyence. You can change drive frq in 100Hz increments from 100-20,000Hz. You can change minimum drive, minimun break, neutral brake and dead band are adjustable in 1% increments. You have 4 memory slots to save setups in. For example this lets you set up 4 diffrent drive frqs which you can switch track side in seconds for back to back lap time testing.
Short Answer:
It does a lot more than the LRP's and KO's.
We can get them in a smoked black case or a blue see through case. However, we only stock the blue ones.
AdrianM is offline
Old 09-01-2004 | 04:32 PM
  #160
I switched from a Quantum to a Zero V Ex last year, and the Keyence was a better Speedo - simple as that.
Now have a new Rapida Pro sitting on the desk waiting to be fitted for this weekend.
MattW is offline
Old 09-01-2004 | 09:33 PM
  #161
Unfortunatly I managed to blow mine up!!! running the com too small, won't make that mistake again.
This would have to bee the best speedo I have ever used hands down. The best feature is being able to adjust brake frequency. The higher it is, the sooner the brakes fade as you slow down, making it easier to brake just right everytime.
Dragonfire is offline
Old 09-02-2004 | 07:35 AM
  #162
Pyramid's Avatar
Registered User
In case no one have not mentioned it yet,
if you are looking for spedos in the market, once you tried keyence products, you will not wanted anything elses. Keyence disadvantage is only being big in size compares to other escs today, bit most of todays TC car is already underweight and other electronics on the car are getting smaller and smaller. I'm talking about the high end Esc, so rapida pro versus other high end type from other brands. One thing you will defenetely love, aside from all the functions, with the same gearing, using keyence will make both of your comm and brush last 3 TIMES longer compared to other brand. You would love seing others truing comm on every 2 or even 1 runs while you sitting and smilling wacthing them.
Pyramid is offline
Old 09-02-2004 | 09:04 AM
  #163
AdrianM's Avatar
I'm old school...big speed controls are Tekin G-12cIII's & LRP V6's. The Keyence is tiny in comparison and fits in any current car with plenty of room to spare.
AdrianM is offline
Old 09-02-2004 | 09:41 AM
  #164
JayBee's Avatar
this is very true, I got the zero v extr. 2002 in my Yoke sd ssg and it fit just right. now if I could just find out how to do my servo mod, I'd be set .
- jayBEE
JayBee is offline
Old 09-02-2004 | 09:52 AM
  #165
JayBee's Avatar
Post
AdrianM
I haven't really messed around with my speedo since I put it in, I just set it to program #5 for stock racing. Have you found any other particular set-up on this speedo that maximize the potential of a stock motor. And this is already accounting for proper gearing, correct mesh, and optimum motor tuning.
- jaybee
JayBee is offline
