Hobbywing ESC's
#691
I want to run my HW 150A ( blue) in a SC10 4x4 with tekin SCX 5.5..... i thought i read somewhere that running the 150A on 2S wasnt the best setup.... anyone have any experience or recommendations on how to make it work?
nevermind found my answer just had to go a few pages back LMAO
#692
Im trying to find out if I have the latest version of software. I just installed the 150a xerun and the prog box...when I installed the software it said there was a newer version but when I try to update I get update fail error. Am I running the latest version and why cant I update? Thanks.
Hardware ver: HW437_V5.0_150A
Software ver: V1.00_111207a_2R
#698
Did I just find the right place to get the latest?
http://www.hobbywing.com/product_show.asp?id=218
#701
Go it. Now at 1.64 and no update available beyond that I see. I didn't have WinRar installed so that was a bit tricky but downloaded that and was able to extract the .exe file from there. Using Win7pro 64bit and didn't have to do the admin trick either. Thanks amigo.
#702
Did you calibrate the esc to your radio with the setup button on the switch? Thats my guess! Set radio to rev, hold that button and turn on switch, let off button and leave radio in neutral, press button once, pull full forward and press again, then go full reverse and press one more time.
#703
Thanks!
