Hobbywing ESC's
Old 03-20-2012 | 06:26 PM
  #676
aloksatoor's Avatar
Originally Posted by TCarlson777
I just bought my first HW speedo, the 120a 1s with built in booster. It came with a cap. Should that be installed, as with Tekin speedos, or is it optional? The directions do not mention it. Thanks.
Have to install it between battery terminals with correct polarity. It reduces ripple and increases punch.
aloksatoor is offline
Old 03-20-2012 | 07:01 PM
  #677
BlackStarRacing's Avatar
Default 1S esc
wrong thread lmao please see below....
BlackStarRacing is offline
Old 03-20-2012 | 07:05 PM
  #678
Default Oooppss wrong thread i meant....
i have the SC8 w/ 2700kv HW combo in my SCTE i was thinking about buying the censored 1/8 comp esc and the SCT 4.5T is it worth the upgrade or should i stay with what i have currently?
Daryl
Old 03-20-2012 | 08:09 PM
  #679
Blackpony's Avatar
any ideas as to why my xerun 80 amp will not go into manual program mode? I hold the set button down as per the instructions and the esc just continues to beep until i turn it off them back on. need to reset it so that i can have reverse.
Blackpony is offline
Old 03-21-2012 | 03:09 AM
  #680
I have a new Xerun 150A and Tekin Pro4 4600kv motor. So my problem is that when I put the sensor cable between the motor and esc and I'll put the power on the esc. Starts esc's light to flash green and red at the same time. What's wrong? The motor wiring is correctly installed and the sensor cable is securely in place. Is there motor sensor or cable broken? Or is it because I use 2s lipo battery?
GrazyDriver is offline
Old 03-21-2012 | 06:46 AM
  #681
Three possibilities- 1) Are you holding the switch long enough? It takes an irritatingly long time. 2) Did you calibrate the ESC to your TX/RX already? I think you have to do this first. 3) The switches are shite. I had to cut the one off my slash; the set button was intermittantly sticking down and switching my modes around at random.
porterdog is offline
Old 03-21-2012 | 09:30 AM
  #682
aloksatoor's Avatar
I had the same problem. I could not fix it. Its a sensor malfunction. Tried with the HW 120A esc and the problem does not appear too much though.
Old 03-22-2012 | 07:37 PM
  #683
Blitzrockey's Avatar
Im having the same problem with my hw 120a it works fine till full thorttle with my pro-4 4600 then kicks out of sensored mode and the green light flashes, you can turn it off and on and its fine till full throttle or a load is put on? I wonder what the issue is ? This was with a brand new out of the box pro4. I have a d3 550 3.5 that works perfect with the same esc. COuld it be a sensor board issue with the tekin?
Blitzrockey is offline
Old 03-22-2012 | 08:54 PM
  #684
Has anyone used these in an off road vehicle for a year or more and have had good result?
martin660 is offline
Old 03-22-2012 | 09:28 PM
  #685
I have 3 of them I use for offroad and have never had a problem. LOve them.
Old 03-22-2012 | 09:52 PM
  #686
Dhthmn114's Avatar
I have 6 vehicles... 4 of them are HW powered... Not one single problem!!!!
Dhthmn114 is offline
Old 03-22-2012 | 10:12 PM
  #687
Default Noob question
Whats the difference in the esc 150 black version and the blue version?
Is this going to be a viable option instead of a mamba monster pro esc?
Its going to be hooked up to a 2200kv castle creations motor.
smallnails is offline
Old 03-24-2012 | 05:34 AM
  #688
I still have the problem with Xerun 150A and Tekin pro 4 motor that green/red light flash when sensor cable is connected. But now I discovery something. When I take motor to hand and try test that it work fine. No green/red light flash. But when I put motor at place and I press throttle and pinions take catch and wheels spinning the green/red light start flashing. Do anyone something help that?
Old 03-24-2012 | 05:59 AM
  #689
MrUnlimited's Avatar
Try to upgrade the firmware.
MrUnlimited is offline
Old 03-24-2012 | 06:35 AM
  #690
Esc are hardware version HW437_V5.0_150A and software version V1.00_111207a_2R what is latest. No help
