Hobbywing ESC's
Old 03-12-2012 | 07:33 PM
  #661
Blackpony's Avatar
very good, thanks for the help!!
Blackpony is offline
Old 03-13-2012 | 05:01 AM
  #662
Default Xerun 150
I have Xerun 150A and I wanna run it 2S lipo battery. So I has read there is some problem with 2S but that can be work with BEC. My question is what I have to do... where that BEC goes and how and what kind of BEC I buy?
GrazyDriver is offline
Old 03-13-2012 | 05:27 AM
  #663
Castle Has a Good BEC (Battery Eliminator Circuit)
jdeadman is offline
Old 03-13-2012 | 05:48 AM
  #664
You mean CC BEC Resources 10amp. Do I have to do is solder it in place as shown in picture what is on Castle's page. No other adjustments?
Old 03-13-2012 | 06:27 AM
  #665
Originally Posted by symmetricon
I have the 80amp, and I needed to put in a BEC to get it to work properly. Basically, the 1/8 esc is designed to be run on 4s, not 2s, but using a BEC fixes thes known problems.
i ordered the hobbywing 80 amp esc but a plan on running 3s and 4s would i need a bec or will i be ok
momogt is offline
Old 03-13-2012 | 08:06 AM
  #666
speedy G's Avatar
Correct, just wire it on as shown on the instructions and disconnect the red wire from your esc to the receiver. You can program the CC BEC to put out more volts, it gives more power to your servos but you will need to use the castle usb wire to program it from a computer. The default power output from the CC BEC is a little less than what the ESC puts out, so you may want to program it to maximize the power that your servo can handle, you will notice the difference from running it at stock settings, big improvement in performance after you bump up the power output. Ask around your area to see if someone already owns the usb link, your local hobby shop may even be able to program it for you.
speedy G is offline
Old 03-13-2012 | 08:20 AM
  #667
What He said lol
jdeadman is offline
Old 03-13-2012 | 10:42 AM
  #668
Ok, I understand that abec wil help servo lag and gkitching. But whats the cause of it acting like only the drag brake is working and not my input?
Kbmoss is offline
Old 03-13-2012 | 10:52 AM
  #669
What are the settings in the software?
jdeadman is offline
Old 03-13-2012 | 12:22 PM
  #670
midwestcajun's Avatar
so whats the difference between versions of this ESC? how do you know which one you have? Specifically 1/8th 150a
midwestcajun is offline
Old 03-13-2012 | 02:40 PM
  #671
Thx for answer. So I need this Castle Creations Castle Link USB Programmer Adapter which would cost amainhobbies 21.49$ to program BEC. And because I use Spektrum sr300 receiver and Spektrum s6040 I put BEC volts to 6V or can that be higher like 6.5V or something? Is there problem if it is too high?
Old 03-18-2012 | 07:42 AM
  #672
Default 150a Went Nuclear
Does anybody have any experience dealing with the warranty on HW items?
After 3 packs my brand new HW 150a esc blew the caps. I came out of a corner in my sc10 4x4 and a small puff of smoke came out of the truck. I stopped and when I was looking it over a sizzling sound was coming from the esc. I turned it back on to see what if it was dead and another cap blew. It was like a mini nuke going off.
Kbmoss is offline
Old 03-18-2012 | 08:51 AM
  #673
I sent back an XeRun 150A in the later part of last year, never heard anything.
Although it was sent in for repair, not warranty but either way, I never heard about it.
Shimmy is offline
Old 03-18-2012 | 03:21 PM
  #674
what setting are you guys running on your esc i put a 80amp hobbywing in my 2wd today on 3s it ran flawless until i blew a wheel bearing i had no extras so the slash is down now my emaxx had been setting for a while i put the 80amp hobbywing in my emaxx on 4s with a tacon 4074 2150kv ran 2 packs and the esc was barley warm a my emaxx haul but 21/62 gearing i plan on getting the 150a from my emaxx and run a 6 pole tenshock i love my hobbywing esc
momogt is offline
Old 03-20-2012 | 05:07 PM
  #675
TCarlson777's Avatar
Default Cap
I just bought my first HW speedo, the 120a 1s with built in booster. It came with a cap. Should that be installed, as with Tekin speedos, or is it optional? The directions do not mention it. Thanks.
TCarlson777 is offline
