Like Tree700Likes
FlySky Noble NB4
Old 08-27-2019 | 04:40 PM
  #181
frewster's Avatar
Originally Posted by MrOflam
Nice.
I'm still looking forward to the mysterious blue tooth module. Any word on that?
I haven't asked about it. I would contact them via the form on their website.
frewster is offline
Old 08-29-2019 | 12:22 PM
  #182
frewster's Avatar
Good news: the ~3s delay to switch models in the new 8 channel firmware will be fixed soon.
phattracker likes this.
frewster is offline
Old 09-04-2019 | 08:57 PM
  #183
Originally Posted by iplaygames
by some chance is this all happening at the same track or location?
is it all in the same car? are you jamming a heap of wires into a small box with the rx?
its honestly worth the time cutting wires shorter etc to have less in the box.
are you Browning out the rx with two high powered servos on a low input voltage?
Please let us know what you end up finding, curious...
in nitro im running 2s lipo with two 2282sg servos and not had an issue?
ebuggy is a xr8sct with a savox 1267sg on 7.4v from esc.
rest are in bashers.
This past weekend, I redid all the wiring.
Shrunk down some wires so they were not so long and re-soldered the motor, and moved the receiver and other electrics around a bit.
I did not have the issue once during a few battery packs of running.
gwc likes this.
morvlorv is offline
Old 09-05-2019 | 12:37 AM
  #184
Suspended
Thats such great news! hope you enjoy your Noble NB-4
morvlorv likes this.
iplaygames is offline
Old 09-07-2019 | 10:14 PM
  #185
What RX are you guys using for 6 or 8 channels? I can't find any info anywhere about which receivers work except the 2 that come with it.
viper7016 is offline
Old 09-08-2019 | 04:46 AM
  #186
So I went to the track yesterday and had some issues with my nb4. The steering was twitching, the esc output was notchy and the receiver kept shutting off. After trying a few different setting changes, updating the receivers (both the large and small ones) I couldn't get it to work properly. The car even took off on it's own a few times and ran into the wall or off the track.
The problem was the cheap turnigy servo I was using. I swapped it out for a hitec one I had laying in my box and all the issues went away! Everything was really smooth and responsive the way it's supposed to be.
I know I read a few people were having similar issues. This is want fixed mine.
s550v likes this.
JatoSCT is offline
Old 09-08-2019 | 04:47 AM
  #187
MrOflam's Avatar
Go into settings and change the servo channel to analogue. Fixes jittery servo issues.
Settings, RX set, Servos Frequency.
s550v likes this.
MrOflam is offline
Old 09-08-2019 | 09:59 AM
  #188
frewster's Avatar
You can also change the digital servo frequency.
Had an FGr4S receiver die on my yesterday. It lost connection during a race. When I opened the radio box it was still plugged into power and scalding hot. I opened it up and plugged it in. Within seconds it was burning hot before I unplugged it. A component must have failed dead short for it to get so hot so quickly.
frewster is offline
Old 09-08-2019 | 07:07 PM
  #189
Hobbyking lists the FG4RS receivers as being waterproof. On the Flysky site I can't find anything about them being waterproof. Does anyone know if they are actually waterproofed? I want to run one in a crawler without using a receiver box. I was going to open them up and conformal coat the board, but I don't even have a hex driver small enough for the tiny little screw on the bottom of the case. Anyone know what size that would be?
dway100 is offline
Old 09-08-2019 | 09:19 PM
  #190
what do you mean change the frequency?
i have a couple high end servos that are a bit jittery at center point. I could blow hard on the wheel and the wheels jitter a bit, hah
morvlorv is offline
Old 09-08-2019 | 09:24 PM
  #191
frewster's Avatar
The frequency the receiver updates the servos at. Many servos seem to run at 333hz but you can adjust it up to 400hz on the NB4. You can also set it lower.
frewster is offline
Old 09-08-2019 | 11:09 PM
  #192
Is it trial and error to see what works best?
morvlorv is offline
Old 09-08-2019 | 11:54 PM
  #193
Suspended
personally i would use a traxxas waterproof box and a balloon over the reciever then silicone the end of balloon. when finished running in water, get the Reciever out and let it breath will create alot of heat inside there.
Old 09-09-2019 | 01:13 AM
  #194
I tried that when I first installed the radio. When set to digital the steering servo would go crazy, even after lowering the frequency. I tried analog and that seemed to fix it, or so I thought. The last time I went to the track it was jittery again and the throttle was not smooth. The rx would also shutdown. I swapped out the steering servo and everything changed.
JatoSCT is offline
Old 09-09-2019 | 04:24 AM
  #195
MrOflam's Avatar
Dont know if they use different bolts or not, but mine has phillips screws. Very thin slots, I have one attachment in my duratrax 16 bit tool, labeled "PH000" that fits.
MrOflam is offline
