FlySky Noble NB4
#197
4 channel still shows version 1.0.41 The pdf shows version 2.0.75
My anti virus will not let me download the 8 channel firmware.
Am I on the wrong Flysky page?
NB4 — Flysky
Tom
#198
Is this for the 8 channel firmware?
NB4 — Flysky
Tom
NB4 — Flysky
Tom
#199
I bought a Noble to use with my crawler (lots of channels!) and I can't figure out how to get any of the channels to be 'on-off-on' for the winch. I can kind of do it with the trim switches, but it's more of a 'stay on until you click it back to center' situation. I would like to use the throttle trim switch, as it's in a convenient location, or even the two switches on the side of the wheel, one for winch-in, and the other for winch-out, but I don't think that would be possible. Any of the wheels work, but without a solid stop at center position, I run the risk of creep. Any help would be appreciated as I love the radio, and don't want to look for a different one.
#201
Yes, but the button doesn't always do what you want. For example, I bind the throttle trim switch to channel three, every click acts like a trim click. I.E. it moves the winch slowly out...forever. Or until I click it once back to neutral.
#203
I tried all the buttons. Same issues. I can get an 'on-off' for lights, or a horn. But no 'on-off-on'. I need a 3-way switch, the only ones on the radio that would really work for that would be the trim buttons. Or possibly the ones by the wheel, if I could get them to work together.
#204
#206
I got my Noble in a couple weeks ago and just updated the firmware the other day. I only need 4 channels, so I picked the 4 channel firmware. Since the 4 channel firmware is no longer being developed, should I do another update with the 8 channel? When does it give you the option to select 4,6 or 8 channel using the 8 channel firmware? Is it during the install, or is it a menu option on the radio after you install it?
#207
OMG thank you!!!!!! I installed the 8 channel update about a week ago when I got the radio just so I had it if I wanted the extra channels, didn’t think about the newest update as there wasn’t anything about it in the change log.
#208
#210
700Likes
