Icharger x6 Mini 30A Discharge
#91
When I ran 17.5 TC we would run a cycle charge/dis/char I had no delay all at 40 amps. My packs would be about 110-120 degrees at best but the IR's were 0.6-0.8 per cell all the time. Didn't hurt the packs at all.
With that in mind I now run MOD tc 5.0 turn and my packs after a run are 130-140 degrees.. So the pack is getting used much harder in mod then it was with all the 40 amp charge and dis charge...
#96
Trader Rating: 89 (100%+)
Charging
I want to switch over to this higher amp charging . Can I get away wih just the charger and power supply or do i need the discharging bank?
What is the benefit? Quicker discharging?
#98
without a discharge resistor you will maybe get around 4 amp ... to get 30 amp discharge you will need a resistor or use a lead acid battery
#104
