Icharger x6 Mini 30A Discharge
#76
I pulled it off a old computer.... go to Amazon put in heat sinks and decide which one you want. I haven't decided how I was going to do the finished product yet. once I get the heatsink I want I will get a part number for you
#77
slow down tex.......I'll be at the track this weekend or give me a call
#78
#80
I'll put it this way ... i would not pit next to a person using a warming blanket.
#81
#85
Super Moderator
Isn't a warming bag illegal at most races? I've seen 4 lipos go up in flame. 3 have been from warming bags / blankets (in all cases from experienced racers) and the other from a turbo charger gfx.
#86
You discharge at more than 40Amps during racing in many classes, all lipos should handle that easily.
#89
#90
With anything comes common sense. you can use a warming pouch to keep your battery warm, not cooking, if you discharge your packs down to 6v or 6.4 or so you will be able to use a warming pouch to keep your pack at a nominal temp until you are ready to charge, then you can charge them at 6 amps if you like and they will be at a good temp to run. All you have to do is time your charging according to your run. The real danger to me is cooking your batteries at high amps just so you can charge in 10 min.
