Icharger x6 Mini 30A Discharge
#121
#122
Those little fans are cute and all but don't do anything to cool the resistors down, ended up with a 70mm pcu fan ... keeps the temp at >200F
#123
Super Moderator
How are you able to use 5 resistors ?? are they all 1ohm 100watt ?? My RL power supply made a weird noise and shut down permanently when I hooked up 5 resistors, it worked fine on 4. Now the power supply turns on for 8 seconds and shuts down I verified this with 2 older computer power supplies, they both worked fine with 4 resistors but burned up with 5
#125
Mopar, If you are using the Discharge+ function, it should not do anything to the power supply itself. It sounds like you have Regenerative discharge mode set instead. This will destroy power supplies like you have noted. Please disable regenerative discharge, otherwise you will destroy every power supply you connect it to. It must be getting expensive at this point.
Marcos.J, The resistance of the wires and connectors can reduce your discharge rate. The wires or connectors must be hot to the touch, yes?
R = E/I = 8.18 / 26.5 = 0.308 Ohms. Your wires and connectors comprise about 0.58 Ohms. Try larger wires, larger connectors, and double-check solder joints.
The resistance of the discharge bank is not a secret. Please read my posts earlier in this thread. Comment #33.
#127
Super Moderator
#129
If you don't already go to rcgroups.com, you should check out their battery forum as Junsi has been active there. That's where they have also posted all the latest FW.
#130
#134
#135
Has anyone figured out how to discharge a 1s pack at 30A?
