Icharger x6 Mini 30A Discharge
#211
So I have read the majority of thread and I have a pretty good understanding of the calculations for the discharge resistor bank needed. My question is once this bank is hooked in series through the positive lead between the charger and the battery, can I actually use the battery cycle feature that the charger offers without removing the resistor bank during the charging portion of the cycle?
#212
Super Moderator
#213
#215
#217
Why not making a switch over it?
Open = discharge
Closed = charging.
Open = discharge
Closed = charging.
#218
The question specifically asked if they could use the charge/discharge cycling function with the resistor bank plugged inline. The answer is no, you cannot. The only way you can use the traditional cycling function is to
A. Be limited to the internal discharge capacity of the charger
B. Utilize a power supply that is capable of absorbing the wasted power
If you disagree that an iCharger DUO is superior for this task then I challenge you to a cycling race. You can pick the battery we are going to be cycling. You get to use any combination of power supply and/or discharging bank on your X6 and I get to pick any combination of power supply and discharging bank I want for my 406 DUO. First to complete three charge/discharge cycles has the superior setup for cycling. Up for the challenge?
#219
Super Moderator
#220
#221
#222
#223
Obviously its superior to the X6 in almost every aspect ... but it also costs around 3 times as much
But the X6 is a LOT smaller
And yes you can use the 30A cycle just as easily as long as you are hooked up to a 12v car/motorcycle/lawn mover battery.
#224
Yes, the form-factor of the X6 is tiny compared to any of the Duos... until you have to lug a group 27 deep cycle battery along with it
I know some of the drone guys use large lithium packs as the power source out in the field (where no other power source is available) to run their chargers. Perhaps this is an option with a large-capacity 4s if you set the regenerative cutoff voltage to somewhere around 4 volts per cell during the regen discharge cycle? While it would be an expensive option, although not much more so than a large lead-acid deep cycle battery, it is also much smaller and lighter.
#225
Super Moderator
honestly how many people cycle their packs during a raceday ? i dont i cycle them at home maybe once a month. usually you have a delay between discharging and charging right? so my delay is the time it takes me to unplug and plug and push "charge" in all is about 5 to 7 seconds
