Icharger x6 Mini 30A Discharge
#181
I just got my X6 in the mail yesterday. This little thing is an absolute beast! But I had a question....
All of the Junsi software I've found (namely the firmware updater) is being marked as malicious in Windows 10... and I can't really tell if it's legitimate or simply because it's unsigned. Has anyone recently downloaded and installed? My X6 is on 2.0.3 and I want to update to 2.0.4 to take advantage of a 10a discharge.
#182
Super Moderator
#184
#185
I tried last night to update my charger but every time I went to upload the display would shut off. The only way to get it to come back on I would have to pull the power and it would reset. Not sure were to go with this and looking for some input.
#186
Try doing the upgrade via a SD card instead. I had a similar problem and the SD card upgrade worked fine.
#187
Is there a way to use the Extra discharge feature for a 4s pack? I don't want a lot but I would like to have the ability to discharge over the 30w allowed by the charger. I've built some resistor banks for my 2s packs but for some reason it won't do the extra discharge feature through a 4s pack. I'm using a .5 ohm 200w resistor. All I really want from the 4s is like 4-5 amps. When I set it to 5A the charger will hit it for a few seconds then the 30w safety limit kicks in and wont allow it.
#190
