Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Project: Break in Dutch machine >
Like Tree20Likes
Old 10-04-2016 | 05:47 AM
  #91
Roelof's Avatar
Richard is ready with his first batch and is now busy with making it all ready for shipping.
Roelof is offline
Old 10-04-2016 | 08:26 AM
  #92
fyrstormer's Avatar
Holy crap. What does this accomplish that you can't accomplish with a normal break-in?
fyrstormer is offline
Old 10-04-2016 | 08:52 AM
  #93
Richard E's Avatar
Yup that is right Roelof.
I have started delivered of the first limited production of the EBIS units beginning of this week and preparing the rest of the first batch for shipment.
Best regards,
Richard
The initial break-in under fully controlled conditions, perfect lubrication, perfect temperature, fully controlled RPM ... I think it is self-explaining. Subsequently the engine performance & life time is accordingly.
Originally Posted by Maximo
I give up waiting for this, I am going to produce my own now !
Did you order from me??
Richard E is offline
Old 10-04-2016 | 10:40 AM
  #94
Roelof's Avatar
- No burn out bumpstarters
- No scratches on the piston due a tight fit, the piston actually comes out as a mirror.
- No load on the conrod so no replace after the break in
- No wasted time on the track
- No wasted fuel
- No wasted tires
- No wasted glowplug
- Can do it at any moment, even in the winter you can prepare your engines.
- And finally a perfect fit of the piston in the sleeve
Roelof is offline
Old 10-04-2016 | 10:48 AM
  #95
Maximo's Avatar
Best regards,
Richard
I was likely one of the first to contact you
I have been very patiently waiting for your second email to tell me how much they cost....
Maximo is offline
Old 10-04-2016 | 12:36 PM
  #96
YBSLOW's Avatar
- No wasted fuel
- No wasted tires
Exactly!!!
YBSLOW is offline
Old 10-04-2016 | 02:43 PM
  #97
Perfect break in .......every time!!
JOSE CASAS is offline
Old 10-04-2016 | 03:11 PM
  #98
Richard E's Avatar
Very well possible. In case you were really one of the first, I might not have been ready to answer yet at that point of time, since I had never produced such a machine before, other than my personal prototype. You will appreciate it is not a business for me, as I have to do everything in my free time outside my office hours, just trying my very best to satisfy my RC friends around this globe. In case you want to build your own, respect. In case you are still interested having one from my EBIS production units, just drop me a mail.
Old 10-05-2016 | 01:28 AM
  #99
Very cool.
James73 is offline
Old 10-05-2016 | 02:56 AM
  #100
Respect!!
-X-
35Plus21 is offline
Old 10-05-2016 | 07:54 PM
  #101
fyrstormer's Avatar
- No wasted fuel
- No wasted tires
A mirror-finished piston sounds pretty nice. But how can it break-in the piston and sleeve properly if it doesn't use the connecting rod? The connecting rod determines how far the piston travels upwards in the sleeve, and no other part will produce the exact same fit.
Old 10-05-2016 | 08:35 PM
  #102
It does use the connecting rod. It rotates the entire rotating assembly via the crankshaft. Since its only spinning a couple hundred RPM's instead of normal operating speeds, the accelerations the conrod experiences is much smaller which results in way lower stress.
thunderbt3 is offline
  #103
WHo said he wasnt using the conrod? Have you read the entire thread and understand how this machine works?
nitrodude is offline
Old 10-05-2016 | 10:45 PM
  #104
Roelof's Avatar
Because there is no combustion heat the piston will run more free through the pinch zone giving less forces on the rod. That together with 100% oil and low speed makes the rod unharmed.
Roelof is offline
Old 11-22-2016 | 11:35 PM
  #105
RC-Netshop.dk's Avatar
Hi fellow EBIS drivers ,
Excellent machine Richard has made!
Can't wait until spring )....
http://rc-netshop.dk/en/offroad/1786...n-service.html
All the best,
Niko
RC-Netshop.dk is offline
