Old 07-01-2004, 03:04 AM   #106
Ybakoff's Avatar
Where can I buy a Zac pipe from. I was trying to get one of there modded motor's but I can't find them anywhere.
Ybakoff is offline   Reply With Quote
Old 07-01-2004, 05:28 AM   #107
Regional Moderator
daniz24's Avatar
A lot of my friends are selling their OS ZAC very cheap (new and used) since JPs have more power bandwidth especially in the bottom. Too bad you are in Australia
daniz24 is offline   Reply With Quote
Old 07-01-2004, 10:16 AM   #108
markp27's Avatar
Send a message via ICQ to markp27
Default Idle Gap
Hi Guys,
I've run my JP FX in and tuned it to the best of my ability (needs some practice, I think!). What surprised me however, was that the gap on the throttle barrel wasn't very big - I see figures of 0.5mm to 1mm often quoted.
My engine is running @ 108 Degrees C after a good 10 laps of hard running. When release the throttle trigger after a flat out section, the revs go to idle relatively quickly (i.e. don't stay high for a few seconds - which I think indicates LSN too rich) and the revs don't increase.
I've used the pinch method (i.e. pinching the fuel inlet tube) to see if the engine is running rich or lean. When I pinch the tube next to the carb inlet, the revs rise for 0.5 to 1 second and then die off pretty quickly. This should indicate an ok tuned LSN, no?
Have a look at the pic attached, you can see my idle gap - let me know if this is ok. BTW: Normally the insert is in, I just took it out to let you see the gap better.
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 07-01-2004, 10:22 AM   #109
ziggy12345's Avatar
Looks ok to me and the explanation shows that its in tune.
I would have thought you could run the engine hotter than 108. What are others running theres at
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 07-01-2004, 10:40 AM   #110
markp27's Avatar
Cheers
Cool
I was just at the end of my run-in cycle, so I'm just building the temp up slowly. I've got the JP FX with ceramic bearing, does this mean it can run a little hotter than normal?
No one else is running JP FXs at my track, so I'm not sure what temp I should be running the engine at. Any tips would be welcomed
Thanks, Mark.
Old 07-01-2004, 11:31 AM   #111
Ron C.'s Avatar
Originally posted by markp27
Cool
Thanks, Mark.
Hello markp27,
No, the bearings doesn't mean you can run the motor a little
hotter. On the other hand, ideally, the motor should run a bit
on the cooler side since the ceramics allow the internals to
have more ease and smoothness when in motion.
About the temps..
If you are able to run it at your current 108 C with ample power
and run time, I suggest to keep the temps within that range.
But ofcourse, this number will always differ depending on the
current conditions on the day you are running the motor at.
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 07-01-2004, 11:38 AM   #112
MrChan's Avatar
Send a message via ICQ to MrChan
Cool
Thanks, Mark.
I have been running at my track about 97 C ... give me enough power ..
MrChan is offline   Reply With Quote
Old 07-01-2004, 11:54 AM   #113
markp27's Avatar
Originally posted by jwf-ronni
Hello markp27,
About the temps..
Thanks for the info
Old 07-01-2004, 11:56 AM   #114
markp27's Avatar
Yeah, the power is really great.
I'm running the 3-port version. The other day a guy setup a radar-gun to check the speeds of the cars at the fastest part of the circuit.
A guy running an MRX-3 1/8th got 92 kph, a 1/10th runner with an MTX-3 only managed 60 kph and me, a solid 90 kph
Old 07-01-2004, 11:57 AM   #115
markp27's Avatar
and run time
Is there ever ample power
Old 07-01-2004, 07:09 PM   #116
Regional Moderator
daniz24's Avatar
Default Re: Idle Gap
Maybe you could lean your LSN a little bit more. And yes, your idle gap is about the same to us.
Cool. Is that means they now allowed you to join the 1/8th scale racing with your 1/10th car?
Old 07-01-2004, 11:09 PM   #117
markp27's Avatar
Default Re: Re: Idle Gap
Thanks - it is reasuring that I'm going in the right direction. Ok, I'll lean the LSN a little bit more.
Once I get my old 705 fitted with the Lola body and JP FX engine, I'll be creaming the 1/8th guys
Old 07-01-2004, 11:39 PM   #118
InitialD's Avatar
It's the car I tell ya...
Geez, are you sure it's the 1/8th scale and not the 1/5th scale lawnmowers?
Old 07-01-2004, 11:54 PM   #119
markp27's Avatar
D!!!! don't blab about the car stick to the plan remember!!! The car is a piece of junk, made out of glass in fact! It's better to buy something else
The lawnmowers were impressively fast: 72kph
Old 07-02-2004, 12:37 AM   #120
InitialD's Avatar
Ooophs, apologies Master Mark. Slip of the finger ! Anyway, it's not mentioned in the FAQ to keep silent.
I would rather get hit by a 1/10th scale running at 90 kph than getting hit by a 1/5th scale at 72 kph !
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
