Like Tree1Likes
JP engines
Old 08-26-2005 | 11:07 AM
  #481
gfd2726's Avatar
nice!
gfd2726 is offline
Old 08-26-2005 | 07:40 PM
  #482
edracer1's Avatar
Originally Posted by daniz24
... Maybe there will be another engine modified by JP Racing but the deal is not done yet
You're talking about the O.S.TZ right?
edracer1 is offline
Old 08-26-2005 | 08:35 PM
  #483
daniz24's Avatar
Regional Moderator
It's an OS but not the 12TZ line. Currently the testings are only for the 1:8 buggy engines.
daniz24 is offline
Old 09-04-2005 | 11:14 PM
  #484
Z-Mann's Avatar
does any1 know some basic needle settings for the jp nova s3\
is it a 3 needle carb???
seems a lot of work tuning this engine
Z-Mann is offline
Old 09-05-2005 | 06:04 AM
  #485
ElectricConvert's Avatar
Try this for a starting point. 3 turns open on top end, 1.75 turns open on middle, 2 turns open on bottom. Adjust idle screw for stability. Note that the mentioned settings are from a fully closed posiiton. Adjust the settings to track conditions.
ElectricConvert is offline
Old 09-06-2005 | 05:01 PM
  #486
wendellc1's Avatar
Got the chance to drive the car w/ JP mod (Full Options) this weekend. The engine is broken in (30 tanks) and it's still not making the power. It's fast but not fast enough. I had a couple runs with a stock Mega (just broken-in 20 tanks) and he was able to pull on me. I am pretty sure he was running 30% vs mine running 20%, but his car was obviously quicker in every aspect. I was using an older RD Logic pipe and will test the car again in a few days with the new JP pipe.
His engine was running at 203F mine was at 210F.
wendellc1 is offline
Old 09-06-2005 | 05:06 PM
  #487
jeffreylin's Avatar
Try the Skyline pipe. I've also found that you need to run the JP rich on the low and lean on top to get the power out. It runs on the hot side but no sign of overheating.
jeffreylin is offline
Old 09-06-2005 | 05:16 PM
  #488
wendellc1's Avatar
When I first hit the track, the engine was very rich at the bottom. It was so slow, it can barely shift 2nd even at 200F! I lean the bottom about 1.5 turns and the engine ran a lot quicker but still slower than the stock Mega. Now the bottom end is set just below where the engine is idling high. The temp is about 215F and it's still blowing out a lot of smoke. What temp should I keep it in?
Old 09-06-2005 | 05:22 PM
  #489
jeffreylin's Avatar
I run mine at 240-250F easy. Perhaps you need to lean the top more. Every engine is different but as long as you have smoke coming out and it comes back idling normally you should be okay.
The pipe makes a big difference too. Try the JP pipe and see.
Old 09-06-2005 | 07:06 PM
  #490
daniz24's Avatar
Regional Moderator
What is your needle setting and what is your head clearance? The good starting point is try 1.0mm on LSN and 0mm (flush) for the HSN. Mine now is 1.3 and 0.3 and running very good with low temperature. What fuel are you using? Try Novarossi or JP Turbo pipe. Kawahara ZAC pipe will produce the best power from my experience but with lower fuel mileage.
daniz24 is offline
Old 09-06-2005 | 07:11 PM
  #491
daniz24's Avatar
Regional Moderator
One more thing, the difference between switching fuel from 16 to 20% or from 20 to 25% can be like night and day. Choosing wrong plug and wrong clearance can also make your engine run slow but hot.
daniz24 is offline
Old 09-07-2005 | 08:13 AM
  #492
wendellc1's Avatar
Currently, I am still using the stock plug that came with the JP engine. It's still looks pretty good. The fuel I am using is Trinity's 20%. Compared with Blue Thunder' 20%, Trinity is a lot faster.
Old 09-07-2005 | 08:17 AM
  #493
wendellc1's Avatar
What percentage of fuel can I go up to without adding a shim? I hate to open up the engine simply because it has the blade screws holding the head.
Old 09-07-2005 | 08:35 AM
  #494
jeffreylin's Avatar
Up to 20-25% would be okay. If you are not blowing you plugs you are okay.
Old 09-07-2005 | 08:43 AM
  #495
daniz24's Avatar
Regional Moderator
You never change your plug after more than 30 tanks? I usually change to new plug and fine tuning after the engine is broken in completely.
daniz24 is offline
