Like Tree1Likes
Palmaris engine thread
Old 01-07-2007 | 07:51 PM
  #2476
uniquexme's Avatar
Edward, may i know when can u sent out the crankcase? i have sent so many pm and emails to you, but there is not reply.
uniquexme is offline
Old 01-07-2007 | 07:55 PM
  #2477
uniquexme's Avatar
may i know which exhaust is the best for palmaris engine? is nova 2630 good?
Old 01-08-2007 | 01:35 AM
  #2478
razzor's Avatar
Im running a JP 2620 with medium manifold and its going very well ,just a bit on the thirsty side.
A lot of guys recommended the Skyline VR12 Plus ,so I ordered them from Raceday.I also tried a Mega 2607 but its now where close to the JP.
razzor is offline
Old 01-08-2007 | 03:30 PM
  #2479
Yeah, the 2630 is a good pipe with the PR12 and is my favorite for all around performance. I like the JP 2620 for top end and Nova 2630 for low end. Medium length header in most cases but I use them all to tune for the track.
Surge is offline
Old 01-08-2007 | 11:22 PM
  #2480
uniquexme's Avatar
my frenz has this BRB, fitting into Nova RB crankcase, use nova LL5 crankshaft, OS P6 turbo, with RB carb. ok, recently, he got his needle mixture mixed up, so our frenz help him to retune, we found that his LSN is only 1/2 turn, then he changed a new glow plug, ran for 1 round, and the plug blew off. so may i ask wats the problem here. previously it was ok for him, powerful engine, but now, i help him open up his engine, there is these vertical scratches on the piston. and turbo head is very slightly rough (meaning overheat i assume). so how can we help him out? thanks.
Old 01-08-2007 | 11:24 PM
  #2481
uniquexme's Avatar
Any idea if the new axial green head engine would be better than palmaris PR12? or its exactly the same?
Old 01-09-2007 | 04:12 PM
  #2482
It sounds to me like the engine was detonating which caused the plug to blow and the pitting in the head button. I suggest adding .2mm head shims, see how it runs, then remove a .1mm head shim if it runs ok.
Depending on the size of the scratch, you probably won't have to worry about it. If you still have compression (different than pinch) then run it. I've run Palmaris piston/sleeves with huge scratches and they are still fast.
I would suggest also that 1/2 turn out on the bottom end is a little too low. Try turning out at least 1 turn then retune top end after you add the shims.
Surge is offline
Old 01-21-2007 | 04:45 AM
  #2483
uniquexme's Avatar
wondering if anyone has tried this engine with Kyosho T. Shimo pipe?? is it good???
Old 01-30-2007 | 01:57 PM
  #2484
I haven't tried that pipe but the thought had crossed my mind.
Surge is offline
Old 01-30-2007 | 04:27 PM
  #2485
uniquexme's Avatar
i think it should be good coz its only 5mm
Old 01-31-2007 | 05:59 AM
  #2486
I'm sure it would be. Give it a try to let us know how it compares to others.
Surge is offline
Old 01-31-2007 | 06:08 AM
  #2487
razzor's Avatar
any tweeks to PR12 BiMetal or BRB to make them sing a bit more ??
Mega Masmo and CRF's are embarressing me ,so much so I am contemplating getting a CRF or even Murnan modded one.
We run 16%.
razzor is offline
Old 02-05-2007 | 05:24 PM
  #2488
uniquexme's Avatar
dismental my engine yesterday, but found only now i realise that the piston pin (the 2 clip that secure the piston) is very different from OS, as in OS, there is a tiny bent bit where u can pull the clip out. At 1st i thought it was broken, thereby causing my engine to have few scratches on the piston wall. but then i check again, it seems that both sides are the same. so my question is how are we suppose to remove the clips to replace the conrod?
Old 02-05-2007 | 07:01 PM
  #2489
teammpp's Avatar
Use a scalpel or other sharp fine bladed knife to hook the clip out.
teammpp is offline
Old 02-05-2007 | 07:23 PM
  #2490
uniquexme's Avatar
but there is no thing that u can hook it. so i was wondering if mine has broken
