Palmaris engine thread
#2401
Is been a while
have been doing testing/ tunning lately and finally had a chance to try 16% Nitro.
I was surprise the setting I end up with amazing result. Torque was as good as 25% but the top speed was little slower and lap time is the same.
PM me if anyone interested the setting.
#2402
hello guys, i have heard alot about Palmaris, but it seems that its not popular here in malaysia, so may i know if its really that good? also i noticed that there are 2 PR12, 1 with 8fins, and 1 with 11fins, is that different batch?
i am considering on getting a new engine, but still can't decided, so can some1 pls advise on my list below?
1. Max Power SL3
2. Sirio Evo 3
3. Nova Plus 12-3CT
4. Palmaris PR12
1. Max Power SL3
2. Sirio Evo 3
3. Nova Plus 12-3CT
4. Palmaris PR12
#2404
I'm pretty sure the internals were the same on both of those but we change the head because it was hard to get the temp up with the 11 fin head
#2408
this would be ideal yes, but if a motor cools so well it can't hold a temp the first thing a guy is going to do is lean it out so much he destroys the motor, and then ask's himself why did it grenade, it was only 240 it shouln't blow. but what he relises is that he leaned it so much there was not enough fuel. you can only lean so much. some people will run those motors at 300 degrees,they say thats where they perform. so less fins will help a cold natured motor hold a consistant temp ( in no way am i saying that PALMARIS motors are cold natured)
#2409
oic, thanks bro for teaching me on that. btw, how well does this engine performed, compared to those Nova 12-3CT, Sirio Evo 3, Max Power SL3? also would you be able to share the photo of the linear and crankshaft? i heard that its original with no mod, is it true? based on the fact that it cannot be modded?
#2410
sorry i do knot have this motor, but i do know the guy that makes them, well from being on here. he now makes motors for AXIAL. his theory on the motor is to make motor that will run as fast or faster than modded nova's sirio's picco's etc. what you would see in some pro modded motors you will see in this motor the first time you open it. he also make a different sleeve that will go into nova's and sirio. they are a bi-mtel sleeve. i have read grat results from racers aboutr it. another motor you will want to investagate is the AXIAL 12RR. same philosophy in the design of this motor, badass out of the box
#2412
i would have to see it to tell you that, but i'msure they may be some way to mod it. i'm not 100% sure what mateareal the PR12 has for the sleeve. as far as the crank and case it is already done the same way it would be as if you sent it to someone to have it done. that was the thought behind his motor. to run it box stock and win no aftermarket mods needed. i do know Ron Atomic won the rc pro series race with a unmodded box stock Axial 12RR. their Bad
#2413
Originally Posted by uniquexme
is it true that BRB cannot be modified? Does the PR12 comes with modified linear and crankshaft and body? where can i get it, coz i would like to know how much it cost.
Gas flowing will help any engine and the BRB is no exception. However, the cuts in the sleeve cant be as extreme as some modifiers will do on NOva based engines. I have one set in my possession that was fully modified for testing purposes and the result was awesome bottom end but at a lose of top end.
#2414
1. Max Power SL3
2. Sirio Evo 3
3. Nova Plus 12-3CT
4. Palmaris PR12
1. Max Power SL3
2. Sirio Evo 3
3. Nova Plus 12-3CT
4. Palmaris PR12
The BRB was THE "THING" and popular when 1/10 were hot some 1 year back. Some top drivers over here in KL were testing/using it, with great success, A-Main in Dengkil race (you should know how big a race that was back then), and B/C main in Asian Mugen Cup Finals. So in terms of performance, you can be rest assured that Palmaris is FAST, if not faster.
I'm running the Palmaris BRB set as well, running along with my fellow rc mates who are running 5-porters at HPC, the power is always good and I'm not at all handicapped by using the Palmaris 3-port. One might need to get used to the tuning aspect of the BRB set as it is quite different than the tuning of the other 5-porters.
#2415
hmm, i thought that its always better to have more fins, so that its cooler, and u can lean more?
1Likes
