Like Tree1Likes
Palmaris engine thread
Old 04-18-2005 | 07:46 AM
  #1636
EdwardN's Avatar
Originally posted by BundyMan
Ed, sorry off topic.
Aren't the current F1 engines using bi-metals after beryllium was banned since year 2001?
Rgds
It was banned to use for brake pads and it has nothing to do with liner-BRB never been use as liner on real cars.
F1 uses Al block cyclinders, not Bi-metall.
EdwardN is offline
Old 04-18-2005 | 07:49 AM
  #1637
tl2111's Avatar
Well done Palmaris Racing HK, soon we will be following in OZ land
tl2111 is offline
Old 04-18-2005 | 07:52 AM
  #1638
teammpp's Avatar
Ed,
Mercedes/Ilmor used aluminium beryllium for the cylinder blocks in F1 race engines during the 90's before Ferrari pushed to have it banned. But I dont believe anyone ever used Bi-Metal technology.
teammpp is offline
Old 04-18-2005 | 08:51 AM
  #1639
EdwardN's Avatar
Originally posted by Palmaris Europe
Ed,
I do belive in this, a lot of Al alloys containing very exotic materials, but it is still Al alloy, not a Bronze.
Edward
EdwardN is offline
Old 04-19-2005 | 09:09 AM
  #1640
T-shirt's Avatar
Originally posted by daniz24
I give my one and only .21 BRB P/S which I bought from kitracer (Thanks Chris ) to one of our best buggy driver here and he promise he will test it on his JP FX21 B5 and give me some result.
daniz24,
is it to John agus
T-shirt is offline
Old 04-20-2005 | 05:32 PM
  #1641
daniz24's Avatar
Regional Moderator
Psssst...
daniz24 is offline
Old 04-21-2005 | 01:15 PM
  #1642
Ron C.'s Avatar
Originally posted by Surge
I suggest you try the leaner bottom end/richer top end setting. I saw a BRB engine tuned like a normal Nova engine and the engine was not near as fast as when retuned Edwards way. I think the bottom end needle was at least a turn leaner Edwards way than the other way. That's just an example. It may not be the same for every engine, so start 1/2 leaner then move slowly from there.
Todd,
YGPM
Ron C. is offline
Old 04-23-2005 | 07:52 PM
  #1643
Speedypeterb's Avatar
Default centax clutch
Hey Chris,
i would like if you could explain a little on adjusting the clutch. what we are looking for when the clutch is adjusted properly? and also the effects of loosening or tightening it and if so what are the effects or purposes of it. and what it does to the opperating temp. of the engine and the response it has on the car in or out of the turns and so on. Some we may know already but also always ready to learn more. thanks Peter
Speedypeterb is offline
Old 04-24-2005 | 06:43 AM
  #1644
daniz24's Avatar
Regional Moderator
Finally I can get this thing scream on today's race. It runs between 115-120C but still kinda rich on the bottom. And also the fuel mileage is still a problem for 5 minutes heat. I'm using O'donnell 25% with 0.5 mm shim (on JP FX crankcase) with Nova 52607 pipe and 7Tf plug.
daniz24 is offline
Old 04-24-2005 | 09:34 AM
  #1645
markp27's Avatar
I have a similar question to daniz24:
I ran my 2nd JP FX Palmaris today and I have a head clearence of 0.4mm (measured with a piece of solder wire). I run 16% fuel and a 6TF plug. Air temp was around 16C.
I found that the power was excellent, but I couldn't get the temp above 100C without it leaning out completely.
The car would bog down (lean not rich) coming out of a hairpin after a few laps. At first, I thought it was the LSN too lean, but even after richening the LSN right out, the problem persisted.
I leaned the LSN back again (it idled at 70-75C) and richened the HSN, the power was back, but the temp after a hard run was 85C.
Is this because the head clearence is too small?
If I put another 0.1mm shim in, would this stop the engine leaning out at low temperatures?
Cheers, Mark.
markp27 is offline
Old 04-24-2005 | 10:12 AM
  #1646
EdwardN's Avatar
Cheers, Mark.
Hi Mark. Take one .1 mm shim of and it will change behavior of engine. With 16% nitro-0.4 is little bit too much. lease remember you are running EFRA cranck with 7 mm hole and it is different to outlaw ( IFMAT, ROAR) type (7.5+ hole).
Edward
EdwardN is offline
Old 04-24-2005 | 10:13 AM
  #1647
EdwardN's Avatar
Daniz, I would sugest in your case lean bottom futher and slightly reach on top. 115-120 is pretty good temp.
Edward
EdwardN is offline
Old 04-24-2005 | 10:24 AM
  #1648
markp27's Avatar
Edward
Cool!!! Thanks for the advice, Edward - will do.
I almost had to change my underwear when my JP FX Palmaris hit the track - I could hardly bring it to a halt before the hairpin at the end of the straight - I thought I was going to have to order some new parts for my car
markp27 is offline
Old 04-24-2005 | 11:30 AM
  #1649
kitracer's Avatar
Default Re: centax clutch
Originally posted by Speedypeterb
Hey Chris,
Peter, I like to set the bell clearance little further away from the clutch. It seems to work really well at our track which is fairly open or at track with good grip. Especially using BRB
RRR = 0.6mm
MTX3= 0.6mm
710 = 0.75mm
When the clutch is set properly, the engine' sound should be really "crispy" exist from a corner.
Most time, when I reset the clutch for guys at the track, immediately the Engine temp drop, next I lean the LSN to bring back temp... speed improve and use less fuel.
Other things to watch is the clutch shoe. When it is shinny, change it.
kitracer is offline
Old 04-24-2005 | 12:48 PM
  #1650
EdwardN's Avatar
Congratulation to Todd Bathh with his 2nd place on South-West series race today. He was running REX RER with BRB 2nd generation in it and V1RRR car. Great job Todd!!!!!!!
Also congratulation to Pit-RACER with his 5 place-using NS12 with BRB 3 rd generation and S710 car.
Go Texas!!!!!!
EdwardN is offline
