Old 01-26-2004, 09:26 AM   #136
stefan's Avatar
Send a message via AIM to stefan
How about this?
Colors can be changed.
stefan is offline   Reply With Quote
Old 01-26-2004, 12:00 PM   #137
EdwardN's Avatar
Originally posted by stefan
How about this?
Too bloody, no, something else.
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 01-26-2004, 12:32 PM   #138
Data's Avatar
edward:
the design of the engine is very interesting and thank you for showing it saturday. you got to show me the carb. when it is ready, it probably is as interesting as the rest of the engine. looking forward to run against one soon.
what is the advantage of using a "nelson" (?) plug on a car engine ?
data
Data is offline   Reply With Quote
Old 01-26-2004, 01:19 PM   #139
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default nelso plug
Isnt a nelson plug the same thing as a torbo plug?
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 01-26-2004, 01:20 PM   #140
Default edward
hows this?
Old 01-26-2004, 01:23 PM   #141
EdwardN's Avatar
Originally posted by Data
edward:
data
Right after the winternats I will give you chnce to run against it or run it.
There is couple advantages to use Nelsons. Design of end where filament located is much wider and create very big flat area, but in the mean time diameter of tunnel for filament is realy small and protect filament very good from overheating. Glow wire on Nelsons are realy durable and last much longer even under very high compression ratio. Sealing design has wider tapering and don't damaged the seating place on the head. But there is one big disadvantage, which basecaly needs to be solve-hexogen is bigger size and regular glow igniter doesn't fit there. S I will need to build one. Regardless everything I will try them, both types-regular and globee.
Old 01-26-2004, 01:24 PM   #142
EdwardN's Avatar
Default Re: nelso plug
Looks similar but litlle bit different.
Old 01-26-2004, 01:50 PM   #143
Data's Avatar
thank you for the offer but it would be more interesting to run against one. by the way, what gearing were you using saturday ?
Old 01-26-2004, 03:41 PM   #144
EdwardN's Avatar
Tallest module 1.0 mm MTX3, I belive 46/42 spurs and 17/21 pinion, but may be wrong ( I am not car's guy )
You will run against it, can promise you for sure.
Old 01-27-2004, 09:23 AM   #145
C Verano's Avatar
Default Very Nice Motor
The case on the motor looks similar to the type of motor that's used in FAI pylon racing...If your motor runs like that, I'm pretty sure it'll be fast. Is the motor designed to use the Nelson or Globee plug only? Or will you sell them with the a standard turbo plug button?
Chris
C Verano is offline   Reply With Quote
Old 01-27-2004, 09:38 AM   #146
modellor's Avatar
Will be available with standard and turbo plugs. The Nelson and Globee plugs are only a thought for better performance if they are legal
modellor is offline   Reply With Quote
Old 01-27-2004, 10:13 AM   #147
Default topgun777
Edward this one fits, and it is slower enjot it. Your T/Shirts are on the way they were shiped today.
Paul.............
Old 01-27-2004, 10:53 AM   #148
EdwardN's Avatar
Default Re: Very Nice Motor
Chris
yes it will be very fast and you know what I am talking about.
It is already very fast.
We will have three different type of bottons to supply. But seems like for european market mostly will be for normal plug, for ROAR and IFMAR it will be mostly Turbo, but can be supply both types, no problem.
Nelson-it is under experiments and have no info yet. It is required special glow starter.
Old 01-27-2004, 11:02 AM   #149
EdwardN's Avatar
Default Re: topgun777
Paul.............
Paul, it is working now and I love it.
Old 01-27-2004, 11:27 AM   #150
C Verano's Avatar
Default Re: Re: Very Nice Motor
I think you can use a standard ignitor if you just push down and hold it there. It definitely will not lock onto the larger body of the Nelson or the Globee.
Palmaris PR12 .12 1/10 touring car engine boy2rc R/C Items: For Sale/Trade 0 01-29-2007 09:28 AM
Palmaris Racing EdwardN Monster Trucks 0 11-26-2006 08:56 AM
Palmaris Racing EdwardN Electric Off-Road 0 11-26-2006 08:48 AM
Palmaris PS12 engine for sale boy2rc R/C Items: For Sale/Trade 0 08-10-2005 09:05 AM
Palmaris PS12 for sale boy2rc R/C Items: For Sale/Trade 2 03-16-2005 06:15 PM
