Like Tree195Likes
Novarossi engines thread
Old 05-24-2016 | 09:18 AM
  #5146
Thanks Roelof. That is interesting to know.
James73 is offline
Old 05-24-2016 | 12:48 PM
  #5147
hi all l have a problem with my keep on 21 in that i can not get it to idle down
after coming off the throttle it takes about 20 seconds to setle to idle.i have the
idle gap set at 0.6mm if i richen the low end needle it's still the same then cuts
and i can richen the high end to the point where the car won't change gear
with little effect am i missing something or doing something wrong as i'am new to
onroad
thanks rick...
rick oxley is offline
Old 05-24-2016 | 06:45 PM
  #5148
RoketRdr's Avatar
onroad
thanks rick...
If you idle hangs after WOT that normally means your HSN is too lean. If it drops to idle and then goes back up that means your LSN is too lean. If you have richened the HSN to stop the problem but now it wont change into second gear you need to adjust your transmission clutch. Tune your transmission around the engine not the other way around. And always tune the HSN first and THEN the LSN. Don't mess with the LSN until you have the HSN properly tuned. Sounds like you need to go back to base line needle settings and start over. Also you need to check and make sure you don't have any air leaks as that will cause similar symptoms. Your fuel tank cap may not be sealing properly or you may have a leak around your carb base.
RoketRdr is offline
Old 05-31-2016 | 12:38 PM
  #5149
which is the best r7 conrod to put in my keep on 21 seems my
distributor has 3 diffrent ones to choose from
thanks rick..
Old 05-31-2016 | 08:40 PM
  #5150
thanks rick..
All R7s will fit in a motor that takes R7s. They do have batch numbers, and theres running changes from time to time, but they will all fit
nitrodude is offline
Old 06-03-2016 | 06:16 PM
  #5151
gearhead_22's Avatar
I have a flash 12 in my 10th scale a I have vp powermaster 20% with 9% oil. is this a good oil content?
gearhead_22 is offline
Old 06-04-2016 | 03:38 AM
  #5152
dan_vector's Avatar
I'd prefer 16% nitro with 9% oil (.12s are designed for 16%). Running higher I would put a 0.1mm shim under the head and up the oil to 11%. OR just run 16%/9% as that will be better all round.
dan_vector is offline
Old 06-04-2016 | 12:48 PM
  #5153
I usually run 16% but can find any locally so I'll hold off till I find some 16%
Old 06-08-2016 | 09:51 AM
  #5154
Anyone have experience with the Top Elite 7 On? It seems very similar to ISON 21, but the cylinder has a different part number. The specs are the same.
Would there be a better choice in the ~$200 price range? How much power would I be giving up going with this or the ISON21 over the latest high-end engines?
jepjepjep is offline
Old 06-20-2016 | 11:36 AM
  #5155
Audiobahnaholic's Avatar
Maximo what setup do you recommend on buggy for a p5xlt? I have an 086 a JP2 and a Reds 2104 pipe to choose from. Also what head shimming and carb insert? I'm wanting a lot of power and good mileage. 30/8 blend byrons
Audiobahnaholic is offline
Old 06-22-2016 | 03:57 AM
  #5156
Maximo's Avatar
make sure to run a bigger 9mm carb insert...very important.............. then try each of the pipes, the real magic is finding the right manifold.........my guess is the 086 but those copy pipes can be al over the map so who knows.
Maximo is offline
Old 07-02-2016 | 07:50 AM
  #5157
Default NOVA ROD #07006 #07009
Hi,
the MITO 35wc uses the #07006 rod (R4).
By any chance will the #07009 (R7) be a suitable alternative?
sam
sammies is offline
Old 07-02-2016 | 10:21 AM
  #5158
Roelof's Avatar
Yes. All "R" rods are te same in dimensions. The R4 is lighter and stronger so they say. but I think The R7 is no difference/
Roelof is offline
Old 07-03-2016 | 04:36 AM
  #5159
noted. thanks roelof!
sammies is offline
Old 07-04-2016 | 09:57 PM
  #5160
Set
Planning to dive into GP 1/10 onroad for the first time, I can get below combo new for around $170, are these a good set to start with?
353 RACE 12/S
TUNED PIPE = NV51611
MANIFOLD = NV41619
at my local track they run 0.12cc 3 ports turbo engine, am I getting the right engine?
Set is offline
