Like Tree195Likes
Novarossi engines thread
Old 06-24-2020 | 07:46 AM
  #5896
dan_vector's Avatar
Originally Posted by HaulinBass
can you run the long LSN with say the GT motors or will it cause a fueling issue?
The Mito GT5 and the Mephisto GT5 both come with long LSN's.
dan_vector is offline
Old 06-24-2020 | 09:59 AM
  #5897
HaulinBass's Avatar
my mephisto GT came with a short needle that leaves the spray bar at about 1/4 throttle, when i tried the longer needle from the 069 type carb if it wasnt out from flush with the housing it would be super lean down low and fat at about 1/3rd to half throttle. with the short needle its fat as hell with the hsn at like 2.25 turns from closed and the LSNat 3 from fully closed(ran 150cc dry in 3.5 min lol). I also changed the fuel tank when i changed the LSN back to the shorty, just trying to bounce ideas around before i start swapping carbs around again to save myself an hour or two of messing around with it. I was thinking it was a lack of pressure at low rpms, I can understand the the short needle will allow more fuel at idle i guess changing both the tank and needle at the same time has me confused as to what really was making the difference. I just thought it was odd when i go over most of the "onroad/gt" novas come with the 11041 lsn so I figured I would ask if the longer LSN would cause a lean condition down low
HaulinBass is offline
Old 06-24-2020 | 10:42 AM
  #5898
dan_vector's Avatar
Thats interesting. I just checked my stock Mephisto GT5 has the plastic carb and it definitely has the long needle that's leaves the spray bar just before full throttle and its always been super consistent with great runtime. For the record my Mephisto LSN (long) is measuring 0.3mm OUT from flush and the last time I ran the engine it wasn't lean at all down low.
I also checked my newer Ielasi Raptor GT5's and these have the alu onroad carb and short LSN and these engines have way more power overall. The short LSN in these engines measure 1.80mm IN from flush as set the last time I ran them. Run time is pretty decent but not as good as the stock Mephisto and so I usually only use my Mephisto at tracks where I struggle with run time as we run 7 minutes qualifying in Europe for GT8.
The long LSN will cause the engine to run leaner of course for more of the throttle movement compared to the short needle and the engine tune is more affected overall when running a long LSN.
Old 06-24-2020 | 11:36 AM
  #5899
HaulinBass's Avatar
must have been a fueling issue stuck the long lsn back in and she ran like a champ and exactly the same for 25 min. My mephisto gt5 was built feb 13 and came from walter hobby in Oz i wonder if a running change was made or they are slightly different when sold to a "hot" climate. Or typical nova throw whatever parts are around at the time in it LOL. Im actually running it in a 1/8th truck offroad 41033/2108.it was running awesome the first race of the year but i ran out of my usual fuel and they went out of business at the same time so had to switch, fuels the tank got changed for the first time at the same time and i just assumed the tank sealed well as it was new. should have known when everything gets super wonky check the fueling system first, then clutch, then the motor.
dan_vector likes this.
Old 07-29-2020 | 11:30 AM
  #5900
mrreet2001's Avatar
R/C Tech Elite Member
I am new to Nitro (other than an HPI R2R like 15 years ago). I picked up an NT1 and Im trying to figure out what to get for it. I know the is rather open ended but, what are the differences in the Nova .12 engines? Mephisto vs MITO vs ISON. I see some come with ceramic and some have steel ball bearings. Which is better in a Nitro engine? The other question I have is what is a good tuned pipe and manifold? Nova seems to be recommending the "51010- (EFRA 2015)". Do I want one manifold over another or do I pick one that fits the car?
Thank You so much for any help in this!
outcast32 likes this.
mrreet2001 is offline
Old 07-29-2020 | 12:09 PM
  #5901
Roelof's Avatar
The 2015 pipe is for an .21 engine so it never can be advised with a .12. I think you are a bit confused because Novarossi is using a same name on both size of engines. So look again on the Novarossi site.....
With Novarossi there is just one rule, the higher the price the faster it is configured. Because it is your first real racer I will suggest not to take the most expensive because you will not use its maximum potential. The ISON is a lower priced engine but still a good performing one.
Steel bearing or ceramic does not matter, on paper performance wise the ceramic runs better, on the track it is hard to tell the difference.
davidl likes this.
Roelof is offline
Old 07-30-2020 | 12:11 PM
  #5902
Cant drive's Avatar
Default 41013 and 41014 ?
Are there any benefits from 41013s, 41013L, and 41014 manifolds compared to the older 41015 and 41016? More power?
Cant drive is offline
Old 07-31-2020 | 12:38 AM
  #5903
dan_vector's Avatar
The newer manifolds have less curve to them and are called 90 degree manifolds. Seems to be the latest trend and they do develop slightly more power overall and I have had a little better runtime with them in 1/8. Not a huge upgrade but if you need a new manifold then go for one of the new 90 degree ones.
Old 07-31-2020 | 06:57 PM
  #5904
Cant drive's Avatar
thanks for the info! Is the 41014 the longest followed by the 41013L and the shortest the 41013s?
Old 08-01-2020 | 02:55 AM
  #5905
dan_vector's Avatar
Just think 41013L is long for more bottom end (technical short tracks) 41013S is short for more top end (bigger more open tracks). We use 41013S almost always on most tracks. The 41014 I believe is pretty much the same length overall as the 41013S but it is even more straight than the others meaning that it doesn't bend down at all. I haven't personally tried the 41014 manifold myself but I do believe it is the most powerful of the 3.
Old 08-04-2020 | 05:18 AM
  #5906
Hi, still no update of re opening of Novarossi factory ? Would be so sad they definitely close.
Thx
gilesdhay is offline
Old 08-04-2020 | 05:38 AM
  #5907
dan_vector's Avatar
Unhappy
Thx
No not yet. Still closed. The Italian summer holiday shutdown started on Monday and will continue until 24th August so most industries are shut until then. No one really knows what will happen to Novarossi but the rumours that they have closed permanently are not going away and it all sounds fairly terminal. It is a desperately sad situation I hope I am wrong and I truly hope that they will reopen in the future perhaps after securing some investment or a buyout. So really for us onroad racers the only real option for me now are OS based engines (not a fan of Picco or Reds).
petersen114 likes this.
Old 08-11-2020 | 09:18 PM
  #5908
sinisterRC's Avatar
Hey Fellas,
Where would I be able to find a spare piston/sleeve for the Mephisto .21? Can't seem to find it anywhere?
Found this, I think the piston would work but not the cylinder..
https://novarossidirect-com.3dcartst...09_p_2829.html
Thanks!
sinisterRC is offline
Old 08-13-2020 | 06:47 AM
  #5909
mrreet2001's Avatar
I think I am going with a Mito .12, a 51614 tuned pipe and a 41616 manifold and 30013 air filter, C6TGF glow plug.
Do I need to buy any exhaust gaskets or springs .. or anything else. I have only built a nitro kit that came with everything.
Thanks for your help.
Old 08-13-2020 | 02:14 PM
  #5910
dan_vector's Avatar
The manifold comes with extra gaskets and all the springs needed. The engine will also come with a glow plug and exhaust gasket but good to have spares on hand.
Please note that your pipe and manifold combination will work but is far from optimal. For that engine you should be running the 2660/51615 pipe with the 41613-S manifold. (The pipe you chose is no longer EFRA homologated if that matters to you and is all top end - not what you want for 1/10 gas).
The INS box that you chose is the red coloured 1/10 unit which is correct but was discontinued by Novarossi sometime ago. If you found one cool however as a backup plan the black one everyone uses is 30017.
