STS engines
#376
Originally posted by GUNPOWDER
Hi,
I had the same question before, Dino gave these factory settings for D5:
Mid Range needle - Flush with the housing.
Low Speed needle - 4 Turns out.
High Speed needle - 4 Turns out.
Hi,
This setting can let you start your engine. When I run at track,I usual rich the LSN to 5 turns out. And lean the HSN to about 3-1/2 turns out to extract full power. It depend on the engine temp. and your driving style.
#377
Today,I got a phone call. One young man who is my friend want me to check his D5 for him and the engine sent to our factory already. As usual I asked him what's going on?
Young man:[Hi,Dino.Please check my D5.It's hard to adjust....]
Dino:[Well,what's wrong with it?]
Y:[Hum....can't idling and easy to cut out....]
D:[OK,I will check it for you. Any other odd condition? Are you sure your clutch setting is ok?]
Y:[No special condition,just easy to cut off when I close the throttle. The clutch setting is fine.]
D:[Well,maybe your engine is too old so the compression is not enough to keep idling. But I need to check it personally. How many fuel have been through it?]
Y:[Hum....not many....about 20 gallons only......]
D:[Well,It should be the reason. The piston and sleeve were worn out already. Let me check it for you tomorrow ok? And I will call you back. ok?...]
Y:[ok! Waiting for your answer,bro. bye!]
D:[bye!]
In fact,I really want to ooxx him on the phone but I restrained mine mouth. I don't know I should laugh or cry.... Sometimes it's strange,the same engine some one can use 20 gallons,but someone may only 2 liters?
Hay guys,lean you engine after making sure the break-in process passed already.
D:[bye!]
#378
Already running a hot plug, but to be fair I have not done the first thing you should do when you hit problems, install new plug so next week before race I will install new plug.
Other then that STS D5 was really nice to drive, I love the powerband it supplies!!
BTW - The long breakin is fine with me, id rather longer compression life
I hope I get 20 gallons out of my D5
Originally posted by dino.tw
Try hotter plug to advance the ignition timing.
#379
Y[/B]
Y[/B]
not much just 20 gallons.... We expect at least 50 gallons of ABUSE..... otherwise money back
#381
I was very happy with my break in on my D5 it was about 4L and that was it. Now after having about 15L its still got heaps of nip you cant push the piston more that 75% up the sleve.
Its just that i got no crank or rod for it. lol
But Dino is fixing me up!
#383
Originally posted by tl2111
STS Dragon has TQ and won in Malaysia National title and MECA Challenge in OZ land
Won two TQ and A Champion last weekend.
Joehwee won TQ and Champion with his Dragon 5/FW05R at Malaysia KKIIR National (130+ entries).
Kyle Hazell won TQ and Champion with his Dragon 3/NTC3 at Australian Meca Challenge (60 entries).
Congrats to those awesome racers!!!
#389
Originally posted by jscamry
stefan: do you have any pics of the internals and outer shots of the engine that you are selling??
thanks Jason
thanks Jason
#390
We are starting to make the crankshaft softer. If you were unlucky and have problem with your crankshaft already,contact with me by email. I will do my best to help.
Sincerely,
Dino
Sincerely,
Dino
How long before the updated cranks will be available for sale in new engines?
I am very interested in a D3 for ROAR racing, and just want to make sure it's the riht purchase.
Thanks,
Jason
I have an sts rs3 engine...where do I get p/s to rebuild here in the states
