Old 08-18-2004, 08:38 PM   #1126
Originally posted by dino.tw
Any other sign? How about the engine temp? Before it misfire is it still have smoke exhaust?
Yes there seems to be smoke.It would misfire couple of times before stalling.Temp was on the high side despite richning hsn.Around 140C.Does the engine needs more shims?
Zizu is offline   Reply With Quote
Old 08-19-2004, 01:59 AM   #1127
Nitro Tech
dino.tw's Avatar
Try 0.4mm shims with 25%. And cold plug due to the weather is hot now. It may stall due to ignition timing too late.
dino.tw is offline   Reply With Quote
Old 08-19-2004, 03:25 PM   #1128
Wink Hello from Puerto Rico
For anybody reading this forum in Puerto Rico, we have the STS line available for local dealers !
Please contact me for details !
B Zayas
ZR Distributors
zrdcorp is offline   Reply With Quote
Old 08-21-2004, 05:25 AM   #1129
Thunder racer's Avatar
Anyone No Were i can get a STS D3. From a HK shop.
I cant find any HK shops that have em.....
they are such a good engine. and they are so cheap........
Dino can i get one from you???
Thunder racer is offline   Reply With Quote
Old 08-21-2004, 02:02 PM   #1130
He can't sell direct
If you come across a good priced D21B let me know
au_Nightmare is offline   Reply With Quote
Old 08-21-2004, 05:24 PM   #1131
f2000racer's Avatar
Try RC-Mushroom
www.rc-mushroom.com
GOOD LUCK!
f2000racer is offline   Reply With Quote
Old 08-21-2004, 06:14 PM   #1132
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Who modd's for rc mushroom I didn't think factory modded them I only know of Geoff to do that
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-22-2004, 05:47 AM   #1133
Originally posted by f2000racer
Try RC-Mushroom
www.rc-mushroom.com
GOOD LUCK!
Thanks man. but no......... Mushy only have the DR now. ther used to have the D# thats were i got my old D5 from. But now they only got DR engine. Which i think is pretty stupid. becasue the old D# engine was Hell Cheap. and the DR engine is way over priced.
Anyway. Thanks
ill just have to keep lookin
Old 08-22-2004, 06:03 AM   #1134
Nitro Tech
dino.tw's Avatar
Anyway. Thanks
You can ask them to order it for you. We still have much stock of D3 & D5.
Old 08-22-2004, 08:36 AM   #1135
Omar's Avatar
what does it mean when your glow plug is pushed in? it only happens in my sts engine only. i only get one run on each plug
Omar is offline   Reply With Quote
Old 08-22-2004, 08:55 AM   #1136
Nitro Tech
dino.tw's Avatar
Too big compression. Install one more 0.1mm shim.
Old 08-22-2004, 07:30 PM   #1137
Omar's Avatar
thanx a lot what, are the stock setting on a sts rs5
Old 08-22-2004, 11:45 PM   #1138
Data's Avatar
Thumbs up finally
dino:
finally get some good performance out of the d5 and the d3, after 3 weeks of bad luck. it was really bad in the morning, both engines would falme out without even completing one single lap. tried everything and nothing seems to work. finally i put a #5 plug in the engines and they run great. is that true that the d series engines like hotter plugs, or it is just mine ?
the modified d3 perform better than i expected (geoff can attest to that ), thank you for the mod tips. now let see how durable these engines are. the d5 still need some work, but i think it has everything to do with the pipe, got to find the right pipe for the d5. any suggestion ?
data
Data is offline   Reply With Quote
Old 08-23-2004, 12:32 AM   #1139
Really.........that great. Ill do that then.
Thankx
Old 08-23-2004, 01:21 AM   #1140
revzalot's Avatar
Default Thanks for the bearings
The D3 is the best bang for the buck. I'm hoping you guys make one for 1/8th scale on road.
www.revzalotmotorsports.com
revzalot is offline   Reply With Quote
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
