STS engines
#526
Thanks Dino, that makes sence
(BTW - Your english is fine!!)
#527
Hi all, Just about to start my D3 for the first time. Where should I set my needles.
#528
Re: Re: Burger
Originally posted by burger
I didn't get the Projet Zen Modded version. Sorry. I probably wouldn't post pics if I did, since it's kind of an intellectual propery thing that could be reproduced if you saw the pics.
J
J
#529
Re: Re: Re: Burger
Originally posted by Top Gun 777
Ouch! I put so many pics of my motor ( Palmaris PS12), so for sure now I need to expect that it will be reproduced!!!!!!!! by everybody!!!!!!!!!!
tks
Chris
#530
Last year I had a sts breakin sheet that said 4 turns out on the high needle, 4 turns out on the low and mid range to be flush with carb body.
I started breaking in my D5 last night and started with this. I turned it out a tad more on the high and low(8th of a turn) to get a little fuel to spit from the pipe to make sure I was rich enough.
Also try preheating your engine to make to piston not stick so much.
Good luck.
#531
Re: Re: Engine Woes
Originally posted by wangcc61
First of all, you should have a silver (0.3mm) head shim.
The copper one is only 0.1mm thick.
My suggestions are:
1. Put the silver head shim back.
2. Rich up the Low Speed Needle a little bit (You might need to also raise the idle screw after you rich up the LSN.)
If you idle the engine for a period of time (let's say after 30 seconds), then, the RPM gets higher and higher when time goes by, that's a sign of a lean bottom end setting. If you have temp gun, check the temperature and let us know how high it is.
My suggestions are:
#532
wouldn't ya know it.....
RRRRRAAAAAAIIIINNNNNNN!!!!!!!
Ahh well...we'll keep ya informed as things go on...
BTW, I was mistaken in my first post...I meant to say I had the silver shim...I do know I have the correct shim in.
#533
Do you use very long pressure line?If so,try to make it shorter a bit.
If presure line is too long,it will let your engine singing. When you close your throttle,the rpm dosen't fall soon.
If presure line is too short,it will let your engine perform not that good at mid-rpm range. The back pressure deliver too fast.
#534
I will keep this in mind.However, I do not have a problem with the closing of throttle...it idles up on it's own, with no throttle input. And when I do blip the throttle, it comes down fine.
I am not sure if I understand completely ...are you suggesting that too long a pressure line may cause the idle to go high, or are you suggesting that too long a line may cause problems with the revs coming down as the throttle returns to neutral? Or are both situations possible?
OMG!!! I think I do see your point though...I just measured my line...being all curled up like it was, it does not "look" too long....however, after stretching it out and actually measuring it, I found that is is close to 14" or 350 mm long ...
Soooo...anyone have a ball park figure as to how long the pressure line should be?
#535
That depends on how much backpressure your pipe generates but if its just sitting there and starts singing after awhile it sounds to me the LSN is a tad too lean.
Currently that's my problem, I am going to lengthen and add a fuel filter to the pressure line, apparently that also helps
#536
close to 14" or 350 mm long...
Almost the same with mine but I'm using STS21 and 9886....
I would keep it as short as possible if the mid-rpm perform well. Your engine may easy to over heat due to not enough fuel to let it cool down when you close the throttle.
#537
STS 21 on-road sample
To whom is interested in STS 21 engine. There are some pictures...
#538
Re: STS 21 on-road sample
#539
Tested it yesterday at our home track(gee chih racetrack). Perform not that bad with my 950R. I got the fastest lap time yesterday 14.6s. The 2nd racer is 14.7s with his M.Collari Sirio/Evolva.
But we do meet some problems in some parts like carb and crankshaft....So need more time to make it better. I'm using RB's carb for the moment...
#540
So whats the verdict??
STS is OK or not? or do I buy a Noverrossi?
