STS engines
#257
Originally posted by au_Nightmare
Dino, Just need a rev limiter with big red light..
Gearing (one of the most important things IMO) seems to be overlooked by a lot of people or is it just not spoken about much in the forums??
My suspicions are around the powerband, the lower RPM motors also make their peak HP lower in the band, meaning that you need to shift into 2nd earlier and gear way up. Never got good results.
#258
Gearing
there is all about!
we race here in Holland only at big tracks 265 meters and No problems at all but you have to look for the right gearing.
depend also wich car you use!
and fuel is a point too a little more oil is always good.
thats why run the R&B concept fuel straight out of the can No problemo
don't forget we race these little bombs on 1/8 scale tracks so you have too take care on a few things like fuel and gearing,shifting
#259
Well I've done it, just placed my order for a D5 woohoo
#260
Hi all,
i have an STS RS5 engine and i need a replacement piston and sleeve set and a new conrod.
Does anyone out there know where i can get a hold on these parts for my engine?
Your help will be very much appreciated.
Thanx
Thanx
#261
Year the D5 is a great Engine. You will have fun with it NIGHTMARE.
Hey mate you got to come race at Mingara one week end.
Theres the web site so you can have a look at the Race dates.
www.mingararc.org.au
Cheers Deano
Cheers Deano
#262
parts
Originally posted by NSW no.1
Hi all,
Thanx
Hi all,
Thanx
#264
Thunder Racer, yeah ill have to try to get to Mingara one day.. just so far for me
jscamry, Ill be running my Dragon on a 60Mtr (I think it is) straight , Ill gear the 1st gear for some good punch and top gear so it does not rev its head off , maybe a 5 tooth spread or something..
#266
Re: Re: Re: crankshafts broken
Originally posted by Top Gun 777
It seems for me the hardening process was choosen not right for this aplication-looks to "dry" for me. They hardened to much all the way through.
#268
Re: MAN!!!!!
Originally posted by Slotmachine
That crank looks like it got very hot! What type of fuel do you use, it looks like it has some NASTY buildup on the crank.
no . . was using 25% tornado. maybe the pix isn't so clear. Bearings were ok, just snapped around the crank.
#269
ok...im new to RS5 STS, black body,puprle heatsink, engine...i got this problem.
recently on a 45 minutes race, my engine stop at around 40mins or less and it won't start anymore...obviously i DNF on that race. I got no problem on a 30 mins or less race...so can anyone diagnose this problem. i know must be some engine tuning problem. thanks. im using 25% O'Donnell with Nova #6tf plug.
#270
My guess would be a little too lean?
