Old 07-22-2008, 06:11 PM   #286
NitroWD's Avatar
Originally Posted by jeff1 View Post
I use 4.78 that is the tallest gear in my car, but I am sure if I could install a taller pinion that won't be a problem for the engine and it will still scream in a 60m straight.. They measured top speed and my car hit 98km/h with this gearing
woah! 98km/h!
how long is yr straight?
will it do any harm to an engine if it's max-out on a straight? meaning yr gearing is too short...
NitroWD is offline   Reply With Quote
Old 07-22-2008, 11:12 PM   #287
jeff1's Avatar
I think it is between 60m to 70m... I am not sure how to measure the straight
I don't know if it will harm, but you will be disappointed with the power if you let the gear too short.. see all the RTR cars smashing you in the straight. No kidding
jeff1 is offline   Reply With Quote
Old 07-24-2008, 01:18 PM   #288
Originally Posted by NitroWD View Post
woah! 98km/h!
that is only 60mph, not real unrealistic actually. I believe I've seen 8th scale cars clocked at 75mph on a 175' straight before.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 07-25-2008, 06:11 AM   #289
1fastdude's Avatar
Trader Rating: 15 (100%+)
75 mph, I'm not sure about that! I know that the Toledo track and the Cincinnati track have had 1/8 scales that were clocked at 65-68 mph, and I'm sure that the straights are at least 175 ft. Where did you see them clocked at 75 mph ?
★RCAmerica •Xray •Hudy •BSR/Jaco •Absolute Hobbyz •Gravity RC •PROTOform •Avid •TQ Racing Wire •C & M Motorsports ★
1fastdude is offline   Reply With Quote
Old 07-25-2008, 06:58 AM   #290
wingracer's Avatar
Trader Rating: 24 (100%+)
I saw 71 on a radar gun at Cinci at the worlds I believe. I think 301 might be a tick longer so 75 is possible I think.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-25-2008, 07:57 AM   #291
98km/h is just short of 61mph. check http://www.convert-me.com/en/convert/speed
This was clocked by a police radar gun at the 2007 sedan nationals track near Houston (on a previous race obviously) there is a small slight S before the 175', I believe the full length of the track is somewhere in the 230 range so you almost start the 175' in 2nd gear.
I believe the absolute fastest sedan was somewhere around the 58-60 range as well but I can't remember for sure because we were so shocked by the 8th scale speeds. Enough police stop by oddly enough even though they claim they are too busy to respond to hit and run accidents (long story, multiple times though) so I'll try and get one to bust out the radar gun again on my new engines coming from IDM for my sedan and my 8th scale. Hopefully the new team mod job is even more rediculous than it was with my last batch, looking forward to seeing them in the next couple of weeks.
Old 07-27-2008, 08:59 PM   #292
Goingfast's Avatar
Trader Rating: 29 (100%+)
I have the .12 IDM,and what is the presetting or starting point for the low and high needle?
I'm trying to reset my carb,reason cause I'm now using pico pipe..thanks
Not new engine..ran maybe gallon of fuel ....
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 07-28-2008, 01:38 AM   #293
NitroWD's Avatar
mine in box stock settings are the HSN and LSN flush with its 'holders'...
i didn't check how many turns from closed though; heard it's not advisable to fully turn-in the screws as it might damage the o-rings or something else...
Old 07-31-2008, 06:22 PM   #294
quietstorm76's Avatar
Default IDM .21 engines
Does anyone have any opinion on the durability of the .21 engine line? I interested in buying one.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 07-31-2008, 06:50 PM   #295
The durability is not in question we have had nothing but good luck with the engines. We have not had a engine failure due to manufacture issues. Daniele hand assembles the engines so you know that you are getting a engine that was hand fitted as well as modified. I think that the performance of the engines speak for themselves though. In the US we TQ'd both 1/10 and 1/8 scale at the Biggie as well as won the 1/8 class. We placed 2nd in the Capitol classic as well. One the Florida state series and the list goes on. In Europe The engine led a lap ahead of the entire a final until 2 turns before the finish Daniele's battery went south and was unable to maintain the 1 lap lead. So I would say that the engines have done well. If you have any questions please feel free to PM and we will help you out the best we can.
xspower is offline   Reply With Quote
Old 07-31-2008, 07:03 PM   #296
Thank you for the reply. That is very good information.
Primary Weapon: ?
Secondary Weapon: ?
Old 08-03-2008, 07:16 AM   #297
NitroWD's Avatar
hi all,
currently i'm tuning my .12 IDM, temps at about 120degC, smoke visible...
the thing is after full throttle and off power, my engine would maintain a high idle for about 3s before dropping to normal idle...is it normal?
or i shld richen my LSN slightly?
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
Old 08-03-2008, 07:46 AM   #298
hi all,
That is about where I run my LSN and my car only idles high for probably less than 2 seconds after a very hard run. It sounds like you could use a little more fuel on the bottom and lean the top some more, although I don't tune by temperature so I don't know what your reading relates to so the top end is all up to you if the engine is producing smoke and never feels overheated (boggy) then try a bit. These engines have a small window on the HSN to produce insane amounts of power and you might be just short of it.
Old 08-03-2008, 02:37 PM   #299
No problem I did not know till last night but we also TQ'd the masters class at the Great Lakes challenge!!! .21 size also.
Old 08-03-2008, 06:26 PM   #300
NitroWD's Avatar
great! a relieve to hear that.
will try again next weekend.
CEN Products SCOOTER29 Rookie Zone 9 09-22-2005 01:57 AM
cen products chifan26 Nitro On-Road 7 09-19-2005 02:50 PM
