Old 06-26-2008, 07:32 AM   #256
YBSLOW's Avatar
What sizes are the bearings in the IDM .12?
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 06-26-2008, 07:36 AM   #257
Team Kamikaze's Avatar
12 x 21 x 5 mm
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 06-26-2008, 07:46 AM   #258
YBSLOW's Avatar
Originally Posted by Team Kamikaze View Post
12 x 21 x 5 mm
Are they both the same size?
YBSLOW Racing
Old 06-26-2008, 12:28 PM   #259
Didn't you ask for the bearing size of the IDM .12?
Old 06-26-2008, 12:51 PM   #260
YBSLOW's Avatar
Ugh, I think so? I have not taken a sedan motor aprt in six months??? I do not have it in front of me right now so i was just curious??
YBSLOW Racing
Old 06-26-2008, 01:25 PM   #261
j/k with you.
Old 06-26-2008, 03:37 PM   #262
YBSLOW's Avatar
j/k with you.
I know.............
Are you and Nigel going to the GLC?
YBSLOW Racing
Old 06-26-2008, 10:42 PM   #263
I know.............
Unfortunately Nigel's school schedule won't permit him to go.
Old 06-29-2008, 07:45 AM   #264
keavze's Avatar
Default IDM evo3
hi guys,
just wana find out how do you know the IDM is an evo3 or evo2?
keavze is offline   Reply With Quote
Old 06-29-2008, 09:01 AM   #265
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Originally Posted by keavze View Post
hi guys,
Says it on the head!
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 07-01-2008, 02:05 AM   #266
keavze's Avatar
oops...
btw, i kept seeing that the IDM .12 needs a lean top and rich bottom...
so...how lean on the top (turns of HSN) and how rich on the bottom (turns of the LSN)? some estimate figures would be nice...
what's the stock settings?
Old 07-01-2008, 04:44 AM   #267
The engine likes to run rich on the bottom and a little leaner on top. More or less backwards of a Nova engine. It really is hard to tell you that this or that needle setting is right for you. It changes with where you are and all the weather factors. Base settings really are high speed needle flush with top of body this is rich and also the low speed to be flush with the inside of the housing not the outside of the control lever that is attached. Remove the lever from the low speed and then make the needle flush like the high speed. This should get you going and as always set the top before you set the bottom.
xspower is offline   Reply With Quote
Old 07-01-2008, 05:24 AM   #268
M7H
M7H's Avatar
Needle settings can even be very different between different fuel brands...
The viscosity between fuels can differ due to the oil they use, which means that on some fuels you can lean your engine more then on others, atleast that is what you think, but in fact one fuel is thinner then the other.
Serpent
M7H is offline   Reply With Quote
Old 07-01-2008, 07:42 AM   #269
Smile
Did not even think to mention that. Oh yeah did I mention the weight of the oil in the different fuels!! LOL Thanks
Old 07-01-2008, 08:37 AM   #270
keavze's Avatar
ya, i know what u mean...
ok, will the bottom be richer than stock setting? (in general...)
what's the %nitro that the IDM comes shimmed for?
CEN Products SCOOTER29 Rookie Zone 9 09-22-2005 01:57 AM
cen products chifan26 Nitro On-Road 7 09-19-2005 02:50 PM
