Old 07-11-2007, 06:37 AM   #196
BGMock's Avatar
WHo Has Go TECH 5 Port in a BUGGY..
What pipes do you USE ?
My New Buggy Has:
-4 Wheels
-Go Tech Massive Mods Stage 6 Engine
Nothing else really matters now!DOES IT
BGMock is offline   Reply With Quote
Old 07-11-2007, 08:46 AM   #197
Rookie 4.6's Avatar
Hi BG Mock I have a 5 port with a recently added turbo head, I bought the motor with no carb and have fitted my old nova p5x carb to it with a 7.5mm restrictor. I also run a my old trusty 6886 pipe, seems to give the Go a nice smooth feel and not so ball tearing! I run an LRP 6 plug and the thing goes like you wouldnt belive!! With this set up I can make 10 min finals in my LSP-R, that is with the stock 125ml tank. I am not running it lean either temps are normally around 130C. Hope this helps!!!
Rookie 4.6 is offline   Reply With Quote
Old 07-11-2007, 08:56 AM   #198
Back on topic please.
Mark you mentioned the new carbs will have a new LSN design. can we buy the new LSN seperate?
by the way i also used a OS turbo 3 plug in my go tech last LRRCC meet as rocket said. yeah it's true, it does idle better with it.
TomB is offline   Reply With Quote
Old 07-11-2007, 10:59 AM   #199
Paradoxmaker's Avatar
I have a 5 port and have been using an Ofna 053 pipe. I have tried a PCR 2027 but like the 053 a lot better.
One of these days i will get a 086 (6886) and try it out to since thats supposed to be a better pipe on the 5 port.
Paradoxmaker is offline   Reply With Quote
Old 07-11-2007, 04:58 PM   #200
MassiveMods's Avatar
HN 2047
HN 2062
LRP 2025
LRP 2063
Nova 086
there is a Dyno read out with a few different pipes on it .. its back a few pages ..
hey Mocky when you doing the drags again ?
Engine development manager Rifling Pty Ltd. Nitro fuel designer : Neo + World record title holder 2012 Austalian Nationals 147.6 KPH , 1 st 2 nd and TQ Australian National Buggy titles 2012. Victorian State title 2012 Neo + , South Australian state title ON and Off Road 1/8 2012 Neo + :-) QLD State Titles 2012 1st buggy & trruggy + TQ Neo + MG66 RX7 1st Sportsman Class Truggy QLD State Titles 2012 !! Nitro Addicts Australia . com
MassiveMods is offline   Reply With Quote
Old 07-11-2007, 05:03 PM   #201
Originally Posted by Rocket42 View Post
Kemo strikes again.
I think i need kemo therapy ...
Old 07-11-2007, 05:17 PM   #202
Hey Tom
Hey Tom i cheked with go tech and yes the new part will be avalable to up grade and it will fit the existing carb
Hotter plugs generally help with idle , the OS 3 is pretty hot .
Old 07-11-2007, 09:48 PM   #203
Rocket42's Avatar
I would like to make a comment regarding break in of these engines. Most people now days seem to prefer the heat cycle method and it has proven to a very easy and reliable way to break in any engine. As far as the go engines go I reccomend using this version of break in with some slight alterations. First its very important before you turn over any engine to drop some oil into the combustion chamber so that the engine is well lubricated from the first bump, I also think its very important to heat the engine up to 200f before trying to bump it. This puts minimal load on all the moving parts and makes it easy to turn over. These engines are very tight so its important to not over rev the engine too soon. I think it would be good practice to add an extra tank to the first step of the proccess and a extra tank to the last step before trying to force the engine to rev hard. Always be sure to set the engine at BDC immediately after the engine is shut off and try to never let the engine run out of fuel on the track. you will not likely have full performance out of a Go engine until after the first 1 to 1.5 gallons so taking these extra steps during break in can really help ease the engine into a good long life.
Rocket42 is offline   Reply With Quote
Old 07-12-2007, 01:31 AM   #204
Brits were always good with their mouths.
And Yanks always brag about everything of theirs is bigger.
Allan is offline   Reply With Quote
Old 07-12-2007, 02:28 AM   #205
Kemorc's Avatar
Send a message via AIM to Kemorc Send a message via MSN to Kemorc
Originally Posted by Rookie 4.6 View Post
Maybe all you guys should tell him what you do for a living
automotive technician.
I've got gas, and I'm PROUD of it... 1/5th scalers unite!
Kemorc is offline   Reply With Quote
Old 07-12-2007, 02:37 AM   #206
BGMock's Avatar
OH Yes Mark, you ask the right question......When the track dries out enough for my new car to release itself.
RED
850HP
Turbo Charged
1400 kg
10.5 " slicks
trans Brake.....
Wheels UP
9 seconds here we come
Another RECORD for ME Soon.....First 9 sec turbo E Series Falcon.....
My New Buggy Has:
-4 Wheels
Old 07-12-2007, 11:24 AM   #207
Kemorc's Avatar
woah.. e series falcon? which falcon...
the one that looks like a chevy corsica or the one that looks like the taurus
what block? 4.0?
Old 07-12-2007, 11:46 AM   #208
kamlooper's Avatar
Russel, thanks for your notes about break in, I will be sure to follow them.
I also noticed you posted that on sgrid.
Of the 3 models of JP pipes, which one woud you reccomend for the 5 port? Primarily running on tight tracks, but with a 140' straight.
thanks
kamlooper is offline   Reply With Quote
Old 07-12-2007, 08:37 PM   #209
Rocket42's Avatar
Out of the JP pipes I would say JP-2 I think that works very good on the 5port in buggy, but it will hold the engine back compared to the 086. The JP-2 will give you good performance and you should still have a very quick car with that setup. If the infield is very tight and your running truggy I would say JP-1, a race is never won on the straightaway.
Old 07-12-2007, 09:10 PM   #210
If I am going more for torque in the truggy, is the 007 any good?
AZT
AZTman is offline   Reply With Quote
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15112 Today 02:42 AM
Go-Tech engines? streetracer745 Monster Trucks 23 11-23-2007 01:43 PM
where to buy go-tech engines rhymster Nitro Off-Road 7 09-07-2007 10:42 PM
