Old 05-18-2006, 01:05 PM   #46
rmdhawaii's Avatar
Originally Posted by Josh Cyrul
Yes I am!!!
Are you going to be piloting the RRR EVO or the RRR WCE? We noticed a RRR EVO in Taiwan...
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 05-18-2006, 01:13 PM   #47
rmdhawaii's Avatar
Originally Posted by mhuse6969
Can you use Nova Rossi glow plugs in this engine?
According to the manual, there are CRF Turbo plugs that you can buy for this engine..
Old 05-18-2006, 01:19 PM   #48
Josh Cyrul's Avatar
jag - Yes, I have been testing at CRF for the past two days. The first day I was really jet lagged so we just broke in one engine and I practiced a bunch just trying to get comfortable with the track and my car. Once my set-up improved, I started working with the gearing and clutch to match the engine for the CRF track. Today, we broke in 2 more engines (these are box stock production engines that Philippe took out of inventory before we went to the track) and did a little more set-up work with the clutch and chassis. We are finished testing for today with a finished car set-up, finished gear ratio and 2-speed setting. The clutch is also very close but we want to test a bit more.
On deck for tommorow is a bit of clutch testing, pipe testing and a few other coming soon options for the engine.
Here is a brief about the engine itself -
Fabrice is amazing and I think everyone will be completely blown away once they see the engine a part and on the track.
Simply put, I had to change my set-up a lot to control this engine. About 1/3 of the way onto the main straight my car would shift gears, spin the tires and I lost control and crashed - 4 TIMES!!!
3 engines, minimum 5 tanks each - All three ran within .05 lap time, no broken plugs, started on first try and run time of over 6:30 each time the engine has been leaned down to racing speed with a head temp right around or just below 200 F.....
If I was not here driving it and testing... I may not believe it myself but it is truely impressive....
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 05-18-2006, 01:32 PM   #49
rmdhawaii's Avatar
Old 05-18-2006, 01:38 PM   #50
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Wow, that sounds too good. Are you saying there is a huge power surge around 1/3 throttle? What percentage nitro were you guys running?
Racing4Evo is offline   Reply With Quote
Old 05-18-2006, 01:49 PM   #51
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
With motors being able to run for 6:30, they will eventually probably make a ruling change that you have to pit within 1 lap of every 5 minute mark in the mains. That is pretty impressive stuff though.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 05-18-2006, 01:53 PM   #52
Racing4Evo's Avatar
What? Why would they do that? Anyone can make their engine run 6 minutes by putting a restrictor in it, it just won't be as fast. You can't punish someone for making over 5 min of runtime if there's nothing illegal about it.
Old 05-18-2006, 02:00 PM   #53
rmdhawaii's Avatar
Sorry, no way.
Old 05-18-2006, 02:02 PM   #54
They will eventually see it as an unfair advantage and put some kind of restriction on it. Laugh at yourselves when it happens.
Joe Cude
Old 05-18-2006, 02:04 PM   #55
rmdhawaii's Avatar
Too bad, so sad. That's like saying you have to turn your thottle down if you produce more horsepower than the other engines... Anyway.. enough on this.
Old 05-18-2006, 02:19 PM   #56
Just like the Le Mans the recent years.... The Audio R8 got restricted, that did they got smaller rear wing etc....
Who knows maybe also be something in RC?? who knows!
Foodie is offline   Reply With Quote
Old 05-18-2006, 02:33 PM   #57
rmdhawaii's Avatar
Mathematically, there is an advantage during longer mains, but longer run times won't necessarily win a race. Setup, engine tuning and driving still play a major factor. I would say that it's not a clear advantage, but certainly one to be considered.
The proving grounds for the WASP REV will be the nats, when hopefully the Ninja T01 (.12) will make their debut as well (mike jones - PM??). Which one will come out ahead? How much will longer run times factor into the results. We'll have to wait and see.
If there is enough protest, the only thing I can see happening, is that the WASP REV won't be approved for use. That's about the only thing that makes sense. Carb restrictors, smaller tanks or penalty pit stops don't make sense. I hope it doesn't come to that and I believe that it's very unlikely.
Old 05-18-2006, 02:43 PM   #58
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
I cant understand HOW they would make it illegal for using too little fuel, if the tank is 75cc and the engine is legal in dimensions it should be no problem..
Just lean the engines and you can get 10 minutes runtime
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 05-18-2006, 03:18 PM   #59
bighurt98's Avatar
Default Make motor ILLEGAL???
Guys, this is the beginning of ground breaking technology. More testing and lots of racing to do, but this is huge for 1/10 scale racing! If the motor is 3 port and meets all .12 motor specs, they can't make it illegal!! They could change their rules to make it illegal, but why?? Someone has sat down and re-engineered the .12 motor, plain and simple!! All other manufacturers will have to step up their games if the want to compete!!!
I want a .21!!!
Capricorn C03/Matrix Tires/Novarossi
Capricorn RC USA/RC Target
Murnan Modified Motors
Desoto Racing
Team Gravity
bighurt98 is offline   Reply With Quote
Old 05-18-2006, 06:18 PM   #60
I want a .21!!!
Well Said!!!
RC_Alan
rc_alan is offline   Reply With Quote
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
