Ninja Engine by GRP
Old 03-01-2007 | 08:33 PM
  #511
sandrixx's Avatar
Originally Posted by MassiveMods
Hey Timmy
here is an article i wrote for another forum out lining theroy behind nitro engines run in , i guess you can make up your own mind what works...
Hi All
Scotty has brought this thread to my attention to help shed some light.
what ill write is my opinion based on my experience and is no way a dig at other peoples methods.
Ok firstly all non ringed nitro engines work on exactly the same principal. Modded or stock, end of story.. They rely on a cylindrycal piston to make a compression seal with a tapered sleeve. When new all engines have a certan degree of tolerated fit. IE how tight it is. When you modify an engine you do not alter these tolerances. There is no need to or gain from it.
Some manufacturers make a looser fit for easy run in. Remember 4 years ago when some engines like the Hypers etc were almost impossible to tun over ? Well what manufacturers have done is decrease the tolerance fit to make it easyer to run in.
What a run in is to break the tolerance down over time to fit the piston to the sleeve. If you do this cold on a bench or hot on the road the effect is the same except the tolerance will be different. The draw back is the engine is designed to work at a certain temp. Nitro will not burn till it hits 95 deg c on average and wont produce good power till it hits over 140 deg c . So heat is essentilal to an engine working properly. having said that the heat generated inside the combustion chamber is much higher than that read outside the engine. Once you bring a cold break in engine up to temp and the sleeve expands to its designed tolerance youre left with a smaller piston to make a fit.. what you get is blow by, this causes erratic temps, loss of power etc..
Anyway . immagine you have 2 identical motors , one run in on the bench , one run in on the road. The one run in on the bench will take less time to run in as its worn the piston against an un expanded sleeve. This is simple logic. Heat makes the entire engine expand, including crank case and to a higher degree the sleeve. If the sleeve is not expanded the piston will wear into it at that tolerance.
So if you want an engine to last , start it , put it on the ground and play with it. if youre a sponsored driver with 3 to 4 free engines a year to race with then run it in on the bench, the engine will come onto power and racing tolerance much sooner. heat cycling the engine will take up to 5 litres to bed in depending on tolerance.., but then it will last ages..
I have tried both these methods. I bought 2 of the exact same engine. I ran one hard and hot from day 1 and the other rich and cool on the bench.
The one on the bench lost all compression after 4 litres and was a paper weight. the other lasted over 35 litres with absolutley no repairs or servicing. That to me is a conclusive experiment.
Cheers MM
wow!! great mind opener..,, escape from the norm. but sir, i need your help to clarify this part..."I ran one hard and hot from day 1 and the other rich and cool on the bench." you mean, u start up and just plainly tune and ran that new engine straight from the box? and the other one running it using the common 4tanks on bench method?...,, im sorry if i sound very confused... many thanx!!!
sandrixx is offline
Old 03-02-2007 | 01:22 AM
  #512
M7H's Avatar
M7H
Originally Posted by FASRICK
Let me guess! M7H You must be Rick V's pit man or
haha, no not at all......
M7H is offline
Old 03-02-2007 | 02:57 AM
  #513
MassiveMods's Avatar
Hi Sandrix
Thats exactly right, i wanted to deliberately cause a malfunction with extreme run in procedures with no regard for the engine. The one i ran in Hard and Hot was basically started, leant 1 full tyrn on the HSN and caned like i had no radio reception... The other was treated like a baby .. and drove like one.. This experiment cost me about $500 AUD but now i know for sure what works..
MassiveMods is offline
Old 03-03-2007 | 08:12 AM
  #514
FF25510's Avatar
got mine
the cooling head seems lighten then others
questions - if i ran 20% , should i add extra 0.1 shim ? it came with 0.3.
Attached Thumbnails Ninja Engine by GRP-ssl10006.jpg   Ninja Engine by GRP-ssl10008.jpg   Ninja Engine by GRP-ssl10009.jpg   Ninja Engine by GRP-ssl10010.jpg   Ninja Engine by GRP-ssl10011.jpg
FF25510 is offline
Old 03-03-2007 | 11:37 AM
  #515
Roger's Avatar
Originally Posted by FF25510
got mine
If you're running 20%, just use the stock shim that came mounted on the motor. I added the extra .10 because im running 30% fuel.
Roger is offline
Old 03-03-2007 | 05:44 PM
  #516
FASRICK's Avatar
I have to give to you M7H you have a good sense of humor
FASRICK is offline
Old 03-03-2007 | 07:49 PM
  #517
got mine
what is that device you have the heads in and what does it do?
Edit: slap myself...I just realized they aren't in anything, but are on a digital scale...
Dredd is offline
Old 03-03-2007 | 09:54 PM
  #518
royfan33's Avatar
got mine
Very nice! I ordered mine Friday. The quality looks great in the pics, can't wait to get mine.
royfan33 is offline
Old 03-04-2007 | 04:20 AM
  #519
nitro_moe's Avatar
got mine
Guys..??
Can you please tell me where are you buying them from.?? I only found it at Border but what hoping to find it somewhere in the U.S., Hong Kong, or Japan.
Please post a link..
nitro_moe is offline
Old 03-04-2007 | 04:48 AM
  #520
royfan33's Avatar
Originally Posted by nitro_moe
Guys..??
I bought mine from Sam@ Team Kamikaze. He always gives me good service and a fair price.
Team Kamikaze
royfan33 is offline
Old 03-04-2007 | 05:34 AM
  #521
nitro_moe's Avatar
Team Kamikaze
Thanks for the reply Roy..
It seems to me that all .12 ninjas come with the pipe. So how come Winner's Circle are selling the engine a lot cheaper than other retailers..?? Is it possible that they are selling it without the pipe..?? Does Ninja offer such an option..??
Old 03-04-2007 | 07:46 AM
  #522
royfan33's Avatar
I know the engine will be available without the pipe, but it seems the kit is the only one dealers have in stock at the moment. I've seen the engine only for $230 or so. I wanted the pipe, so the kit made sense for me.
royfan33 is offline
Old 03-05-2007 | 03:11 AM
  #523
Kanea6's Avatar
hi i just bought a ninja .12 on sunday, and i cant get it to fire the glow plug is fine the glow warmer is fine everything is fine. ive been trying for 2 days now to get it to fire it just wont fire. please help me iam at my wits end
Kanea6 is offline
Old 03-05-2007 | 04:16 AM
  #524
Default got the ninja ! =)
the ninja does look good eh? =)
feels at home in the mtx4...
lance04 is offline
Old 03-05-2007 | 05:03 AM
  #525
nitro_moe's Avatar
Are you serious..$230 ?? Please post a link as soon as you can. This is one deal I won't think twice about.
