Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Arrow Racing GTR .21 Engine Thread >
Old 11-30-2014 | 07:09 AM
  #1366
Originally Posted by cczjordan
Browse back few pages, mine:
Lsn-flush
Hsn-2.5 to 3 turn out from full close
Msn-1.5 to 2 turn out from flush
Idle gap factory shud be .7-1mm
If engine stall after fire up, lean lsn a bit till idle good, if u had some experience, reduce the idle gap.
After break in leave the msn, it will give good torque, lean it for mid/top end
Maybe others will have better idea
How do you compare this engine with the UDP? does it has more low or high RPM power? how is fuel consumption?
nosepick is offline
Old 11-30-2014 | 06:22 PM
  #1367
cczjordan's Avatar
Udp is 4 port, new champion 5 port, totally difference in timing n power band. this engine best to compare to mugen ninja, fuel economy depends on tune n pipe, 8-9min easy
cczjordan is offline
Old 11-30-2014 | 06:56 PM
  #1368
We are running the new v4 indoors with the arrow pipe.my friend gregb ran the whole 10 min main without pitting.fuel mileage is very good on this engine.
xxxntwv is offline
Old 12-01-2014 | 01:13 AM
  #1369
cczjordan's Avatar
I think so. The pipe make it smooth n good power with reasonable fuel consumption
Old 12-29-2014 | 07:20 AM
  #1370
cczjordan's Avatar
Will the plus (+) works with os 2060 pipe? Have 1 buy never tried
Old 12-29-2014 | 07:22 AM
  #1371
Intech BR-6's Avatar
Yes
Intech BR-6 is offline
Old 12-31-2014 | 04:42 PM
  #1372
Autocratic's Avatar
Anyone have the v4 motor in a truggy?
Autocratic is offline
Old 01-06-2015 | 02:01 PM
  #1373
I would like to know the same thing also I have at truggy and was wondering the same thing
TRUGGYRACER1 is offline
Old 01-07-2015 | 08:02 AM
  #1374
Frank Hodits's Avatar
The 5 port works great in Truggy.
Frank Hodits is offline
Old 01-07-2015 | 03:42 PM
  #1375
Anyone else??
Old 01-08-2015 | 02:35 AM
  #1376
cczjordan's Avatar
Did u see anyone running ninja in truggy? Hope it give u an idea
Old 01-18-2015 | 11:43 PM
  #1377
BPro's Avatar
What is a good truggy Arrow engine/pipe combo?
BPro is offline
Old 01-19-2015 | 03:04 AM
  #1378
cczjordan's Avatar
Gtr plus + 2103 pipe, more btm
Old 01-25-2015 | 12:25 PM
  #1379
Great motor,first time running it,Still a little tight but managed to run 7 1/2 pretty easy with a 2035/pipe and 6mm restrictor. In mb7r. Thanks Dailed for the motor.9 min motor easy when fully broke in.Still got metal pinch..Really smooth,and all the power you need.
Skillett is offline
Old 01-30-2015 | 08:16 AM
  #1380
cczjordan's Avatar
After fully broken in, what is the shimming for 25%, p3/p4 plug, ambient temp 28-33°c
