Arrow Racing GTR .21 Engine Thread
#616
Breaking in another Arrow today,pain is what i got again!Damn this engine is tight!
run-in 8 tanks,open up for checking,every thing in great condition.
It better to change conrod and pin (And main bearing if needed)after break in,those things are stress big time during break in.
#617
Well, took the engine out for a pit of club racing/practice this weekend. I was going to do a few pipe comparisons, but when I got to the track, I realize that a few of my SPARE parts boxes were missing. (wife cleaning up around the house) So, I was only able to run the OS 2035 on it. I was very pleased with the results. On the stop watch I got 11:30 from pit to bone dry. Track is on the small side,fairly tight, and probably very suitable for a 2035. The engine ran great, and I was very happy with the overall performance!
#618
#619
Man it really shouldn't be that bad if u use a heat gun. At least get the motor to around 170-200 degrees and it should fire up everytime. At least mines did
I too use the heat gun method. Heat it enough and it fire up the first time. To break-in a engine. It should fire up first. Without a heat gun. It would be harder and longer. Pain in the a$$. But you will be rewarded later.
I didn't even need to change the conrod and wrist pin. It is the heat gun method which makes it easier to fire up helps safe the rod.
Mine had over 5 gallons now. And I haven't change one part.
#620
Anyone,
Is it necessary to remove the break in shim after one gallon ?
My first engine was running great with the shim. Fuel Bryon 30%
After I remove it, the engine seems to run hotter. And a little erratic on the tuning.
I put the shim back till now. It all goes back to as it was before.
Question; what does the shim do really ? Will there be a problem if I leave the shim on ?
#621
Anyone,
I wouldn't remove it strictly based on how much fuel it's had. With the glow plug removed, and engine cold, if you can still feel 'metallic' pinch when turning over the flywheel, leave the break-in shim.
#622
#623
Adding the break-in shim removes some compression. Removing it will at first be like reducing the shimming on any engine.
#624
I am thinking about getting this motor to test it out.
#626
