Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Arrow Racing GTR .21 Engine Thread >
Old 04-04-2012 | 05:03 AM
  #646
razzie's Avatar
Originally Posted by twitch_1
i'm running the hong nor 2080 with nice temps 120-125 and getting about 14 min runtime with a 6.5mm ventri with heaps of power
Wow..14mins run time on a buggy? Thats super amazing! I tried 3 tanks and it ranges from 9min 45s to 11 mins with a 7mm venturi. Temp was 120c when it ran out of gas. Of course the pipe plays a major part, but its the fingers and track layout plays a major part as well. As for me, im more than satisfied with the performance and i wouldnt take the risk. Better to pit at 7mins..
razzie is offline
Old 04-04-2012 | 04:55 PM
  #647
joey91473's Avatar
Originally Posted by stallen50
Mine took about 2 1/2 gals what temps wers you running. and what breakin method?
Just driving around the back yard. Engine temps at 210 or so. I think it rips but I can tell once it drops its nuts it is really going to scream. I used the WERKS break in method. I use that on all my engines. I have over half gallon on this motor with 30% WERKS. I am racing it this weekend broke in or not.
joey91473 is offline
Old 04-04-2012 | 05:38 PM
  #648
What pipe ru using? Have u tried the 086 or 2060? What plug ru using?
rossham46 is offline
Old 04-05-2012 | 07:07 AM
  #649
Yes that's in a buggy on a good medium size track medium grip as well...
I'm much the same but when you race against 5 of the top drivers in the country on a club day just to make the A, I need good runtime cause every little bit helps...
twitch_1 is offline
Old 04-05-2012 | 08:32 AM
  #650
nice quote. racing kinda competitive now. not just the a finals. all finals are tough. the arrow give me better confidence. awesome motor. and it runs along with the big boys which left many smitten
pcage is offline
Old 04-05-2012 | 08:12 PM
  #651
Stewie's Avatar
Has anyone had trouble running Werks plugs in there Arrows?
Stewie is offline
Old 04-05-2012 | 10:00 PM
  #652
James khoo's Avatar
This engine like to run with OS plug P3 and maybe P4.
James khoo is offline
Old 04-05-2012 | 10:59 PM
  #653
Jaz240's Avatar
you should be running OS plugs..P3 for steady idle, easier tuning, P4 for more power and better runtimes
Jaz240 is offline
Old 04-05-2012 | 11:14 PM
  #654
Stewie's Avatar
I thought I would try the Werks plug and it seems to be running fine though. Only issue I had was it didn't seem to want to thread in the head correctly for some reason. Either way, just to be on the safe side I have a new head and some bullitt p3 plugs on the way.
Stewie is offline
Old 04-06-2012 | 12:31 AM
  #655
Same with me confident that i'm going to get good mileage with plenty of power as well and it will run all day long without a problem at all...
twitch_1 is offline
Old 04-06-2012 | 09:35 PM
  #656
rfleck's Avatar
Originally Posted by R/C Lidz
here are the settings for an OS Speed- should be close:
idle- 1 1/8 from just closed
HSN: 2 1/4
LSN: 3 1/2
Mid: 3 1/4 (flush)
Are these the stock settings for the arrow? Ready to put her on the ground after a little bit of break in time.
rfleck is offline
Old 04-07-2012 | 12:16 AM
  #657
Rsickles's Avatar
Be careful turning needles all the way to the closed position (never turn MSN/LSN to full closed).
The needles should be set from the factory, but here is the right settings for an Arrow:
-HSN: 3 turns open from closed
-LSN: FLUSH with the ball link body
-MSN: FLUSH with the carb body (generally, slot pointing around the 9 and 3 o'clock hour - though not always, so do whatever is flush)
-Idle: Set a 0.75mm idle gap with the venturi insert out! Arrow says 0.5mm, but once you fire up the engine for the first time, you can lower it as needed.
Rsickles is offline
Old 04-07-2012 | 02:37 PM
  #658
Jaz240's Avatar
I keep OS plugs in stock so let me know if I can help
Jaz240 is offline
Old 04-07-2012 | 05:03 PM
  #659
joey91473's Avatar
I ran a WERKS plug in the arrow and it sucked. Only running a P3 now.
The Arrow was ripping today. Love it. Running a WERKS 2057 pipe today. Love it. Sounds pretty nasty as well.
Old 04-07-2012 | 07:00 PM
  #660
James khoo's Avatar
Now wE all know this 3 port engine run very good,is there possible they will have modified version like OS speed,or maybe 5 or 7 port?
