Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Arrow Racing GTR .21 Engine Thread >
Old 03-22-2012 | 09:01 AM
  #601
Rsickles's Avatar
Originally Posted by pcage
Can Arrow parts fit into a OS XZB ? My friend is impressed. And like to buy Arrow parts for his OS Engine. The conrod, PS etc. Anyone ?
Con rod, wrist pin clips, front and rear bearings, carb retainer, backplate screws, and the entire carb (just switch whole thing, I wouldn't mess with mixing Arrow carb parts with OS ones). That's it.
Crankcase, backplate, crank, piston, sleeve, head button, head gaskets, cooling head, and head bolts are all different.
Rsickles is offline
Old 03-23-2012 | 02:03 AM
  #602
Beddo's Avatar
Got myself a GTR v2 for my JQ.
Looking at the break-in procedure, am I best going with the usual heat-cycle method, or go by what Arrow recommend?
Going to match the engine to a Losi RE11 and a P3 plug. Should be OK I reckon?
Beddo is offline
Old 03-23-2012 | 06:45 AM
  #603
stallen50's Avatar
heat-cycle is fine. thats what i do to all my motors including my arrow. run p3 plug and alot of us have found about any pipe will work fairly well with the motor. but the re11 would be a good start
stallen50 is offline
Old 03-23-2012 | 08:05 AM
  #604
James khoo's Avatar
Try rpm pipe,and run 7mm venturi.
James khoo is offline
Old 03-24-2012 | 08:53 AM
  #605
Rsickles's Avatar
You mean a RPM brand pipe, or a high-end RPM style pipe?
Rsickles is offline
Old 03-24-2012 | 09:23 AM
  #606
James khoo's Avatar
High-end rpm pipe
Old 03-24-2012 | 10:01 AM
  #607
Jaz240's Avatar
All reports have been positive for most of the pipes out there. So far it seems that the 2 best choices for all around power and smoothness is the Nova 9901, and any of the 053 style pipes. Fuel advantage to the 9901
Jaz240 is offline
Old 03-24-2012 | 10:05 AM
  #608
Maybe I should get one ha ha.. I have those two pipes.. Where would his engine rate power-wise, say 1 to 10?
Herrsavage is offline
Old 03-24-2012 | 10:11 AM
  #609
James khoo's Avatar
After the 2 gallon break in and tune,I changing the rod,pin and ceramic main bearing,then keep it for big race,got my 2nd Arrow ready to run in.
Old 03-25-2012 | 04:54 AM
  #610
has anyone else tried the hong nor 2080 i found it very smooth and liked it great power and good fuel consumption....
twitch_1 is offline
Old 03-25-2012 | 05:44 AM
  #611
James khoo's Avatar
HN 2080 pipe is almost like 053 pipe but better fuel consumption.
Old 03-25-2012 | 06:06 AM
  #612
James khoo's Avatar
Breaking in another Arrow today,pain is what i got again!Damn this engine is tight!
run-in 8 tanks,open up for checking,every thing in great condition.
It better to change conrod and pin (And main bearing if needed)after break in,those things are stress big time during break in.
Old 03-25-2012 | 08:17 AM
  #613
Jaz240's Avatar
Your the first report I have seen with that pipe. Glad to hear you like it.
Jaz240 is offline
Old 03-26-2012 | 01:18 AM
  #614
yer very impressed with it and i would recommend if anyone can get hold of one do so...
twitch_1 is offline
Old 03-26-2012 | 09:10 AM
  #615
lee_double2000's Avatar
Looking at the break-in procedure, am I best going with the usual heat-cycle method, or go by what Arrow recommend?3
Ull be just fine. I did the heat cycle method and it worked out great after breakin. I took it to Revelation Raceway and got 9+ min coming off at 210 degrees. Also matched with the RE11. Had all the bottom and top end I wanted. Also ran Byrons 30%/11.
lee_double2000 is offline
